I am working on my first build, which is Matt Phillips' Millennium III project. Matt states in his write-up of the build that the woofer cabinet (using two HiVi D8 drivers) is 2.1 cubic feet after subtracting driver displacement.
Should I be using acoustic foam on the inside walls or Acousta Stuf? I've seen directions for using one or the other, directions for never using Acousta Stuf in a vented box, directions for only using foam on the inside walls, directions for using both, etc.
If I should be using foam, do I need to subtract the foam from the box volume as well?
Thanks for any and all help.
