Ready to commit some resources to build boxes better and faster. A great day it will be when I can give my jig saw a decent burial! But first a router must be secured. How much router do I really need for use with 1" MDF? Going a little slow and careful is fine, and it seems like compactness must be helpfull, however, I am looking for my one and only.. Accuracy and ease of use being most important, I am looking for first hand advice on the power and features needed. Value is always good so are there brands to consider if buying used? Also, any thoughts about biscuit cutters?
Serious cabinets=Serious tools?
Re: Serious cabinets=Serious tools?
Note, you might not need the smaller circle jig if you get the larger one. It cuts pretty small holes, the jig's ranges overlap.An apostrophe with an "s" does not mean plural.
Speaker's IS NOT PLURAL.
Originally posted by icor1031 View PostNote, you might not need the smaller circle jig if you get the larger one. It cuts pretty small holes, the jig's ranges overlap.
Also, for the router is 2 1/4 Hp necessary - how good or bad are the compact ones say 1.25 Hp? Are they any use? 1.25, 1.75, 2, 2.25 HP?
Ani, with a cheaper solution - (if he has to do smaller tweeters) those up-to 2" bits/chucks(??????) that you can put on your hand drill.
Actually, he'll still need to flush mount - so that won't help.
Forget me.An apostrophe with an "s" does not mean plural.
Bosch, Porter Cable, Hitachi, and DeWalt are the brands to consider. I wouldn't buy one without dust control, 1/2" collet, or a plunge base. I have this DeWalt, as well as two Porter Cables and a Makita, and I use 'em all.
Buy one that comes with a fixed and plunge base. Offhand, I know PC and Dewalt make them, and there are probably others. As mentioned, get one with a 1/2" collet, and I'd also opt for variable speed.
Thanks guys- lots o great info already! About circle jigs,- my infatuation with the Heil AMT appliance makes the small holes very rarely needed. I would think that 90% will be 5 to 7 inches. It seems to me that a homemade jig could fairly easily be fashioned that would perform as well as the jasper types? Any tips on use of these jigs or tricks of your own designs?
Originally posted by ani_101 View PostThe larger one cuts 2 1/4 as the smallest circle and the smaller one cuts 1" as the smallest. How do you cut the small tweeter holes?
They are not very cheap (the least expensive 2" bit I could find was $13, all the way up to $50-$100), but they work wonders for drilling really accurate holes easily. I used them on a drill press with some clamps to hold the wood pieces down. They sell them in sets if you want a lot of different hole sizes. Super awesome tool if you are going to be doing the same size holes a lot.
Originally posted by timk View PostBuy one that comes with a fixed and plunge base. Offhand, I know PC and Dewalt make them, and there are probably others. As mentioned, get one with a 1/2" collet, and I'd also opt for variable speed.
I also have the Bosch -- got mine from Amazon and I believe the price is a bit cheaper now....go figure.
Bryan K.
Midwest Audio Club
Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
I bought one of these on sale awhile back. Super investment.
Is this the tool porn thread?
No doubt Dabs, that Jessem glossy was winkin right at me! Probably wear a guy out tryin to put a hurt on that babe.. I have used the Forstner bits, they run true compared to a hole saw With a drill press I'll bet one could countersink starting with the larger bit then switch to the hole size.
I bought a Skil brand table top drill press when I got my income tax returns back this year. Soon I'll buy a big boy router, probably the Bosch with the wood handles. And then a really nice table saw.
रेतुर्न तो थे स्रोत
return to the source
leviathan system thread
deadhorse thread
shockwave build thread
instagram :: greywarden_13
Yes you can. You do want a drill press because the guide point is fairly large on the larger bits, which will allow the smaller guide point to wander.
If you have any Dayton ND20 work to do, a 45mm Forstner is perfect for the flange.
Originally posted by Aardnsword View PostI have used the Forstner bits, they run true compared to a hole saw With a drill press I'll bet one could countersink starting with the larger bit then switch to the hole size.I was so much older then, I'm younger than that now.
The higher HP units are great to work with. Much better than the 1.25 stuff. They also tend to have a nicer feature set. If I was budget restricted I would look at the Hitachi (comes with both fixed and plunge bases).
