I disassembled an old set of Omega 3-way Tower Speakers for the purpose of making use of the quality of cabinets. I already have all new components from Parts Express, including new caps. I labled the end of each wire carefully upon disconnection. As I began to connect the new L-Pads and drivers, the connections just seemed odd and unusual. I did temporarily connect all components and everything sounds great, but I just wanted to get some feedback on those connections and see if the way the L-Pads are wired to the drivers seems to make any sense. First, I should mention this is an 8 OHM configuration and the goal is for the amp to see an 8 OHM Load. I can't draw very well, so thank you for your patience with this text description of the connections:
Mid Range L-Pad:
#1 terminal to capacitor (or amp +pos.)
#2 terminal to +pos. on midrange driver
#3 terminal to amp. -neg.
High Range L-Pad:
#1 terminal to amp. -neg.
#2 terminal to +pos. on horn tweeter
#3 terminal to capacitor (or amp +pos)
It just seems odd to me how this can work. The wiring of the High Range L-Pad makes sense to me and adheres to the diagram provided with the L-pads, but the Mid Range L-Pad terminal connections (#1 & #3) seem reversed. However, as I have typed it (above) is exactly how the original L-Pads were wired, and it all appeared to be original factory wiring. So does anybody think I may have somehow mixed-up the Mid Range connections? If I had #1 & #3 terminals on the Mid Range L-Pads reversed, would they still be functioning perfectly or at all?
Thanks for your help!
Mid Range L-Pad:
High Range L-Pad:
