miniDSP users read this.
Re: miniDSP users read this.
Hmmm, very interesting. I will have to try some similar measurements on my own MiniDSP units. Which one did you take measurements on?
I would wait to see what others report before writing off ALL MiniDSPs like you have done. That seems a little premature.
-CharlieCharlie's Audio Pages: http://audio.claub.net
Also would be good to specify which one. Noise has been reported with use of the larger (2x8?) models, but not so much for the 2x4. I did not notice any noise with the 2X4.
I am using the miniDSP-in-a-box, i.e. 2xunbalanced in, 4xunbalanced out. I am powereing off on my laptop, what I am lookking at can't possibly be due to a noisy power supply. the WTPro is also powered by the laptop. If it was a power supply problem, it would show on both. Extreme 3rd order distortion, occationally in excess on 100% it coming off of the DSP. Note that the third hamonic is so loud that I can hear in whil doing a sine sweep. You can often here the 2nd harmonic when sweeping a driver well below Fs, but I have never heard this above Fs, and never 3rd harmonic.
Bob
I can't help but think it's a faulty unit. I can't hear anything like distortion from mine while doing sweeps. And others have done measurements without issues to report. I should try taking some measurements.
Thanks for pointing this out.
Originally posted by Bob Brines View PostI am using the miniDSP-in-a-box, i.e. 2xunbalanced in, 4xunbalanced out. I am powereing off on my laptop, what I am lookking at can't possibly be due to a noisy power supply. the WTPro is also powered by the laptop. If it was a power supply problem, it would show on both. Extreme 3rd order distortion, occationally in excess on 100% it coming off of the DSP. Note that the third hamonic is so loud that I can hear in whil doing a sine sweep. You can often here the 2nd harmonic when sweeping a driver well below Fs, but I have never heard this above Fs, and never 3rd harmonic.
Bob
I was really hoping that MiniDSP could output a transfer function of the entire system, but it doesn't so it's not of much use to me. If it did give you a resulting transfer function, it would be a great tool for passive crossover design. You could try different crossover frequencies and slopes, and have a transfer function that you could design a passive filter to reproduce.
Unfortunately since it doesn't give this, its a bit of a pain to extract manually, so I never did buy one.I'm not deaf, I'm just not listening!
Originally posted by devinkato View PostBob - have you posted your results on minidsp's forum? They're semi-responsive there, and you may be able to get a replacement unit (assuming your problem is not endemic).
Bob
I notice fairly significant noise from my miniDSPs when powering from my computer, but I've never done any comparative distortion measurements. The noise is gone when powering from a dedicated supply. As others have said I would try that before writing them off entirely.
Originally posted by Bob Brines View PostRight. I will do that tonight or tomorrow. They're in bed right now anyway.
Bob
USB power supplies are not all built the same - it's entirely possible the miniDSP's is totally unfiltered or otherwise not isolated. Laptops put out an atrocious amount of noise from their power supplies (I can hear the hard drive spinning up through the headphones on mine.)I am trolling you.
