Lepai volume problems
  • Lepai volume problems
    I am definitely not a tech savy person, but I purchased a turntable, speakers, and the Lepai LP-2020 amplifier. I have attached everything, but the volume from the Lepai does not go very high. On it's highest setting it would not be heard from the next room, for example. Is there anything I can try? Do you think it is a defective unit?
    Thanks so much for any help you can give me.
    Linda
    Re: Lepai volume problems
    How ( specifically ) is it all attached.
    I suspect that the turntable is NOT connected first to a phono pre-amp? *
    * Some additional info
    This website is for sale! lh-electric.net is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, lh-electric.net has it all. We hope you find what you are searching for!
      What kind of cartridge do you have on your turntable, i.e. make and model?
      The Lepai requires something called "line-level" input, which does not come from your turntable directly. You need a phono pre-amplifier in between, but there are different types depending on your cartridge: Moving Magnet or Moving Coil, or some with both.
        Linda
        You likely need a phone preamp... magnetic cartridge turntables do not output line level signal so you need a preamp to bring it up to where your amplifier sees enough signal to reach full gain. Just go to the PE store page and search for "phono preamp".
        Also try an IPOD or similar into it and you should get a significant increase in output, then you will know for sure you just need a phono preamp.
        Dave
        If you can read this, thank a teacher.
        If you are reading it in English thank a Veteran
          a low cost model preamp
          another low cost model
          http://www.parts-express.com/pe/show...umber=248-6348 this is the same as the one from mcm
          a better model = http://www.parts-express.com/pe/show...number=245-876
          these are 18 to 50 bucks you can go for 10's of thousands but any of the above should work
            If your turntable doesn't have a preamp, I'm surprised it plays at all. I found that running my 2020 with an MP3 player to test speakers I had to turn the MP3 player volume way up to get full power out of the 2020. The level I normally use with earbuds was not enough. So it definitely needs pretty high level line inputs to drive it.
