Anyone use or test the 2" midrange tweeter buyout?
  • Anyone use or test the 2" midrange tweeter buyout?
    Link: http://www.parts-express.com/pe/show...number=289-127
    Just wondering if these are as good as the price.
    Re: Anyone use or test the 2" midrange tweeter buyout?
    I can grab a couple in the morning and test this weekend.
      Thank you.
        Probably not the application you were thinking of, but I had pretty good luck using them in a test Unity horn
        http://www.diysoundgroup.com/forum/i....msg142#msg142
        Free & Free-form simulator/designer for Passive Crossovers
        SynergyCalc 5: design spreadsheet for Wooden horns and DIY Synergy Waveguides
        Super easy and cheap to make high performance sound diffusers
          Man! They are really small. Maybe I can whip up a little adapter for the test baffle.
            Probably use a Forstner bit - I would also be interested in seeing them rear mounted with a 1/2" bevel.
              Wow, you are fast! LOL Thanks again.
              That looks like fun! I showed my wife, she said we needed to get a new house with a fitness room, then I can build what ever I want! So that might be awhile. But she didn't say no! ;)
              I am thinking rear mounted with a 1/2" roundover. I don't have a bevel bit. I also thought of using 2X, 2" pvc pipe with one at each end. Like the 14 driver $200 system that was at InDIYana last year, sorry I don't remember the name.
                I'll give that a shot john.
                  Originally posted by duanebro View Post
                  ......Like the 14 driver $200 system that was at InDIYana last year, sorry I don't remember the name.
                  Dan N's Contrapesso
                  Bryan K.
                  Midwest Audio Club
                  Speedster | Sub Attaché | The Wildeman | Sean's NLA Towers | COÜGAR, COUGAR II and COÜGAR JR | Triton | Lithium | J-Boom | Trym MLTL | Docere MLTL
                    Originally posted by bkeane1259 View Post
                    Dan N's Contrapesso
                    Ah, yes. I have a ribbon tweeter that could go between the mids. I should look into that more. I can't find a write up on those, is there more info out there?
                      I've used it as a midrange bridge between an 8in and horn tweet, worked great for that
                        Not sure if there's a full write-up. I'm sure Dan would be willing to answer any questions you might have.
                        Here's what he has in his albums:
                        Bryan K.
                        Midwest Audio Club
                          There is a very Therough build log.
                            this little guy is mounted in a round waveguide one inch deep and six inches across on a 4x4 baffle mesured at 21 inchs.
                            re 3.688
                            fs 232.2
                            qts .94
                            qes 1.268
                            qms 3.146
                            Le .227
                            sorry no vas
                            i tested two of the and they were pretty close. if anyone used these let me know and you can have these too.
                              I am looking at these to build a cheap 3 way kit with the SAS Bazooka drivers on closeout... thinking 4 SAS drivers for midbass, two of these drivers per cabinet for midrange, and searching for a tweeter that will match well. This would be the fronts/center, surround would be two SAS drivers, two of these mids, and same tweeter. Can anyone suggest crossover values or a tweeter? I was thinking 750Hz/5kHz with these drivers. Looking to see what I can put together for a very strong front stage with some good attack on the midbass for a reasonable price. I may try these drivers in some other places as well. Thoughts on the surround are two forward facing midbass drivers in a slim cabinet with a midrange and tweeter on each side in a dipole arrangement. Should be able to keep cabinet for rears at only around 3.5 inches deep and 7 inches wide, and will adjust height to get the airspace I need for the midbass.
                              Front/Center driver layout, WWMTMWW
                              Rear, two woofers forward firing, mid/tweeter side firing on each side (total two woofers, two mids, two tweeters per cabinet).
                              Drivers:
                              Woofers http://www.parts-express.com/pe/psho...9-087&scqty=30
                              Midrange http://www.parts-express.com/pe/psho...9-127&scqty=20
                              Tweeter is still up for thoughts
