Hi everyone, not sure what i'm doing wrong - maybe everything, but I download ARTA and did a quick measurement of a pair of Dayton RS150 drivers which will end up as a mid for a 3 way system (200Hz-2Khz). I thought I'd look and see if I can see if the breakup of the metal cone is similar to what Dayton has on their graphs.
Following the below guide and using an ECM8000 microphone, I thought I'd be all set. Oh the audio interface was a Steinberg CI1 USB audio interface.
http://audio.claub.net/tutorials/FR%...ing%20ARTA.pdf
I put the driver on a tripod, facing forward at the same height as the microphone about 1 to 1.5 meters away. To make sure the driver didnt go anywhere, I used a thick rubber band that secured it around the magnet and held it to the tripod. Its in a fair sized room but lot of hard reflective surfaces such as wood floor, glass tables..etc, but thats why I thought the ARTA impulse measurement would be good. I'd basically ignore the reflections from what I understood.
So I'm confused as to why i'm not seeing the huge metal cone breakup and the graph looks too well behaved for me to believe seeing how its not in a cabinet and there is no crossover on it.
So to compare with something else, I took a spare 8" Camber driver which I used in my last DIY 8" two way project and a Vifa P17WJ00
Camber driver
Vifa P17WJ
So can I trust the measurement or could I be doing somthing wrong here? The fact that I have a dip in my Dayton RS150 results at 5K instead of a big peak is whats throwing me off...
Thanks in advance for any suggestions.
Camber driver
Vifa P17WJ
