I've been working on a guide for this tweeter. Pretty interesting being it has what I would call a reverse dome or dished. Won't mention who's it is unless he wants to chime in.
He wanted an ovoid shaped guide or elliptical. After running it through a few different ones I ended up with the one I call L2. Real similar to the one Dan N. is using with the N26A. I was able to reduce the throat size to 1" and also was able to design a phase plug that works quite well with it. The biggest challenge was this tweeter has a peak around 15 kHz and the guide would magnify it. I was able to push it up in frequency and also reduce it by half with the phase plug. I also got about a five db boost around 12 kHz from the phase plug at one point but it enlarged the dip at 60 degrees off axis at 12 kHz. I split the difference and got about a 3 db boost and cut the dip back.
All measurement were taken with the driver about 1' off the floor pointing up with the mic half way to the ceiling. It's about 33" away from the driver on axis. Click on one of the pics in the link and you can go forward and back.
This is Flat baffle vs WG L2 with a base plate to reduce to 1" and a phase plug.
This is Flat baffle 0 20 30 40 50 60. It's basically a 2'x4' board with a 3" thick piece of 703 on top with the driver set down in flush.
This is WG L2 with 1" base plate and phase plug.
This is my prototype
Here is a link you can toggle back and forth between flat baffle and WG2 with plug and WG 2 with and without plug.
Dave
Dave
