Passive Radiators (PR from here on), do not have as much "punch" compared to a properly designed ported system. Most, but not all of us, more or less agree with this assessment. What got me thinking about this topic was the feeling that the cheaper flat disk type PR with a conventional surround only, sounds "dead" compared to a regular cone with a stiff spider assembly type PR. If this is true, then I think that is a clue as to what is causing the difference in sound. My guess is that ALL current PR designs have too much damping. Adding a spider suspension around where the VC normally would be on a PR adds a "spring" effect to the system, maybe that is causing the PR to resonate more than one without a spider. So I propose someone, or some of us, collaborate on experimenting with a PR purposely designed to resonate, (or ring), at a specific frequency, not a normal fs, but a highly "springy" very "under damped" configuration. Audio designers usually design speakers to be well behaved and well damped to not color the sound too much, but a vented port may have a less damped nature than an equivalent PR system. To replicate a vented systems sound quality and efficiency, decreasing the PRs damping should change the sound quality audibly, whether or not it will actually sound "better" is to be determined through experimentation, trial and error. Replacing the spider with either a leaf spring or coil spring of the proper weight and resonant frequency would make the PR actually "ring" at specific frequencies. It could turn out to sound terrible, but it also could be applicable for adding a certain type of punch to a bass system using a such a highly resonant PR. The mass of the spring system may cause a damping effect of its own that will neutralize the wanted effect, but using a lighter spring should counter that. It hasn't been tried yet, but it could be worth looking into, I'd like to have it kept open sourced and available to speaker builders and companies alike for free if it has any benefits or value.
I need help in determining the best way to measure a "spring loaded" PRs actual fs. I have modified a PR with a single fiberglass rod as the spring, but I am stuck trying to measure the fs of a PR. I can upload an image of what I have done so far if there is any interest in seeing it.
