Vifa DX25 tweeter faceplate problem.
  • Vifa DX25 tweeter faceplate problem.
    Alright, so I'm rebuilding my Amiga speakers. I removed my drivers from the old cabinets and everything was going fine until I realized that the screw holes in the tweeter faceplates are depressed, keeping the tweeters from sitting flat against the baffle. Should I try to get new faceplates for the tweeters or will they be ok? Any help is appreciated.
    My messed up tweeter: Click image for larger version
    Normal tweeter: Click image for larger version
    Re: Vifa DX25 tweeter faceplate problem.
    I'd probably file it a little bit leaving enough for the tweeter to be held in place when a screw is in the hole. Also I'd use speaker gasket tape under the tweeter to make sure you don't have a void for air to pass from underneath the tweeter.
    Take it easy
    Jay
    "I like Brewski's threads, they always end up being hybrid beer/speaker threads based on the name of his newest creation." - Greywarden
    Breakfast Stout - HiVi RT2 II/Aurasound NS6
    Imperial Russian Stout - Vifa DX25/Fountek FW146/(2) Fountek FW168s - Built by Fastbike
    Ruination 2.5 way - Vifa DX25/Fountek FW168
    Levitation TM
    - Vifa BC25SG15/Fountek FW168
      Take it easy
      Jay
      +1
      Additionally you can drill a small recess in the area underneath. I would not go through the expense and hassle of obtaining new face plates.
      “I cried because I had no shoes until I met a man who had no feet”
        You may want to try a c clamp and see if you can push the recessed part back up flat. I would put tape or even a small block of wood on the face side so you don't mark it. I'd bet if it got pushed out that easy by a screw it should go back in pretty easy.
        Dave
        Trench Seam Method for MDF
          Originally posted by thekorvers View Post
          +1
          So, put a small countersink in? That sounds pretty smart.
            Dave
            I clamped the depressed parts and it helped. If i file them a bit or put a very small countersink, they will fit snug. thank you.
