Ok, it's time to make it official. I'm going to be offering CNC cutting services to the forum. I am able to do
the cutouts and recesses on premade baffles or make custom baffles and cabinets as well.
**I DO also have the capability to model and cut in 3d, ie: built-in waveguides from
your dimensions, out of real wood or MDF, even stand alone waveguides (out of real wood only)**
You can email me at woodgrafx AT maine DOT rr DOT com (*replace the AT and DOT with the proper punctuation) or PM
me for a quote. I check both at least a few times a day. I will need the dimensions, material, any bracing and the drivers, etc. you want to use in order
to give you a proper quote. If you ask how much a small MTM is going to be I really won't be able to give you an
answer. If you need them completely assembled/finished or chamfers/roundovers etc., be sure to let me know so I can include
that in the quote.
I'll require a minimum 50% deposit to start the job and the balance, including shipping costs, will be due when
it's ready to ship. Shipping quotes will be an estimate, unless stated in the quote. Only when the project is finished will I
be able to give an exact amount.
MDF, maple and birch ply are readily available but I also have access to quite a few other species of hard wood.
Curly and straight maple, walnut, paduk, bubinga, mahonany are some good examples of nice tight grained hard woods. So if
you're interested in something out of the ordinary there's a good chance I can get it. Some of it can be pricey
and more costly to machine but it never hurts to ask.
What have you got?!
Thanks!
TJ
that in the quote.
What have you got?!
Thanks!
TJ
