Hi everyone,
I'm new here, although I've lurked for a while for past projects. I have a 2 part question here for all the rattle can gurus. I'm actually refinishing some speaker tops/bottoms that will be piano black. I'm going the gloss black/clear over top/polishing compound route, finished with a rotary polisher. Here's my question:
For the gloss base coat, should I wet sand the last coat before clear?
If yes should it also be polished with compound and a rotary polisher before moving on to clear?
Remember, I'm using rattle cans here, not automotive paints. It appears that among automotive painters the consensus is not to wet sand the last base coat before the clear (as long as orange peel has been comepletely removed), although many have done it with great success.
Before reading more about it my original plan was 4-5 coats of a gloss black base coat, wet sand the base coat, compound with the rotary, then 3-4 coats of clear, wet sanded, then final polish with the rotary. Can anyone share their experiences with this method along with the products you used and specifics of your methods? Thanks ahead of time. Glad to be here.
