Hey guys. I'm putting together all the things I need for a decent measurement set-up, but I have a few questions regarding a few of the components. I would also appreciate any suggestions as to other items that might come in handy.
First off, here is what I have so far:
Dell Inspiron E1505 with Windows Vista Home Premium. An older laptop, but after a recent RAM upgrade, this thing is still going strong!
Laptop's internal sound management is via SigmaTel High Definition Audio. Only output is the normal 3.5mm (1/8") headphone jack.
Dayton EMM-6 Mic (currently uncalibrated, but I found the cal file on PE's site for mine)
Blue Icicle
Dayton 25' Mic Cable (on the way from PE as we speak)
So far I've downloaded both HOLM and REW. Another forum member suggested that REW would be easier to implement for a measuring noob.
The only amp I have at the moment to power the speakers is an old Fisher 5 channel receiver. This is the receiver I have set aside to do some testing. It's a little older (mid 90's model), but it puts out clean sound at 100wpc. Plus it has manually adjustable EQ level knobs across most of the band. Not sure if that would come in handy for measurement though. For now can I just use one of the L or R channels for a signal? I have a nice Belkin 3.5mm to RCA cable for stereo output from my laptop, and the receiver has more than one 2 channel stereo mode. I also have a pretty solid kit for a 68wpc x 2 LM3886TF chip amp, but I haven't had time to build it just yet.
As far as my questions go, these are ones I searched for but couldn't find answers to:
At what point in setting up everything do I use my mic calibration file, how do I calibrate it, and what is used to calibrate it? I know some have the better Cross Spectrum calibrated EMM-6. For now, the current Dayton cal file will suit my needs, but does Cross Spectrum offer services to calibrate a mic if you send it to them?
When measuring I will have 3 different volume levels to consider. My laptops volume, the amps volume, and the gain on my Blue Icicle. What is the norm setting for all these during measurement? I know there are ways to adjust the dB level in the measurement software, but is there a general rule of thumb for the hardware?
Lets say in a two way speaker, I've noticed that some will send a signal to the woofer, then the tweeter and measure them separately. Others will send a signal to the woofer and tweeter at the same time wired in parallel. Is there a general rule of thumb for these different ways of measuring? Or is it just preference of the user coming in to play?
That's all I have for now. Any advice or feedback is appreciated. Hoping to learn more as time goes. I have all kinds of drivers sitting around now, and plenty of XO components. So this winter I plan on having some measuring fun in seeing what all kinds of crazy stuff I can come up with. :D
Thanks!
Ryan
Blue Icicle
Thanks!
Ryan
