So, with all the talk about SL's LX521 system, I'm itching to try some kind of open baffle system. I want to bounce some ideas around here, so please feel free to deconstruct and criticize the following:
Open Baffle Project WAF-1
Drivers:
Baffle & driver mounting:
rectangular 24" W, 36-40" H, 1.5" THK butcher block baffle
Eminence 12" near or just below midpoint
TD6M centered side-to-side in baffle, very close to top edge
SB29RDCN mounted at top of baffle, firing up into a "speaker spike" conical diffuser
Thoughts:
So, what's the feeling on this concept?
-Charlie
Drivers:
- 12" Eminence Driver: 60Hz - 300Hz
- 6" AE Speakers TD6M: 300Hz - 2500Hz
- up-firing SB Acoustics SB29RDCN ring radiator
Thoughts:
- I did some modeling of the positions of the woofer and midrange drivers, and it looks like these will work well in terms of the baffle response
- The Eminence driver was purchased from extra stock from Sausalito Sound - it was a special order for them. It has 10mm Xmax and a copper shorting ring. Le is 1.1 mH, Qt=0.42, Fs 30Hz. This looks like a good candidate for the low end (down to 40Hz - 60Hz) and the baffle should be heavy enough to keep the vibration down. Should be able to do 300Hz without any issues.
- The TD6M are drivers that I recently obtained and I think this will be a great application for them. Very low Le (0.044 mH). Should have good performance up to and above 3k Hz if needed (but would cross lower).
- With all of this talk about D/R sound and power response of the tweeter, I thought I would try something "different". The tweeter is a ring radiator, so the center of the dome is not moving. The tweeter would be mounted at the top edge of the baffle, pointed up. I would position a metal cone (like a speaker spike) with the point a few mm above the center of the dome. This should result in response that is independent of lateral angle. What happens with the vertical response is a big question mark, maybe just a lot of destructive interference... also very little high frequency energy would be available below the tweeter's mounting point, but I'm not sure that is much of an issue. I would definitely have to try this out alone before committing to it. Plan B would probably be a Neo3PDR.
-Charlie
