Re: Open Baffle musings
All the "normal" issues still apply, especially as one pushes the M/T crossover higher. A waveguide will (typically) increase the center-to-center spacing enough to cause beaming and response irregularities around the crossover frequency (the "sounds different when I stand up" effect), so the "fix" may be worse than the problem. OTOH if the M and T are moved far enough apart that they are completely decorrelated (which is not all that far at 4-6kHz.) it might work OK . . . that's an area where I have no experience and don't find much literature reference either.
If the tweeter response is the issue with these dipole designs, why not put the tweeter into a waveguide and control the directivity that way
