The doors in my MKV Volkswagen are setup with the following:
· Tweeters in the a-pillar
· 4” mids in the center
· 7” woofs firing at my ample rump
Currently I’ve rigged up a 2-way CDT setup in the OEM locations. I’m using the 2-way crossover with the highpass on the tweets, and the lowpass running both a 6.5” and 4” mid, wired in parallel.
It pretty much sounds like crap. Especially where midbass is concerned. Certainly that’s attributed to my faulty attempt at creating a 3-way system out of a two-way crossover.
To address this situation, I’ve decided to replace the CDT 6.5s with the Dayton RS180-4 7" Reference Woofer (4 Ohm). With that, I want to add a low-pass crossover before the Daytons at about 250hz, while leaving the CDT crossover on the 4” and tweeter only. I will not utilize the CDT crossover for the Daytons any longer.
This will be fed full-range by my Alpine PDX 150.2,l which is fine on either a 4 or 2 ohm load. I can actively adjust the highpass filters at my deck to cut off 40hz and below if I so desire.
Can anyone help me in designing and adding crossover components to these Daytons?
