RSS390HF-4 Croaked
Go for it. In the near future they will only get more expensive.
Any other thoughts? Time to build a new circle cutting jig and order an Ultimax?
If you're talking a sealed box, they're pretty non-critical. A little larger won't hurt anything.
Originally posted by Green Machine Mowing View PostLooking at the 18" Ultimax my box (4.5CF) is just a little larger than the box they bundle it with and PE specs for music/HT, anyone see a reason not to cut my baffle and toss the 18 Ultimax in there? This setup will be used for music (mostly rock) and HT. Is 500Watts RMS enough to keep one happy? They sound power hungry.
- Likes 1
Originally posted by Green Machine Mowing View PostI worry about the ultimax being under 87db/watt, with 500 WRMS, maybe that's not an issue.
in 5ft^3 the Ultimax 15 looks pretty good. f3 models @ 30.5Hz. It'll take 370 watts for content all the way down to 20Hz or 500w down to 28Hz. Fed 400Watts its producing over 110dB at 30Hz and 113dB at 50Hz. Yeouch!
You could port that box you have and it may work for the HE but sealed the box is pretty big for it.
I just got a pair of the RSS390HE-22 subs my self but these will be going in a SUV I'm leaning towards 5 cu tuned to 33hz for my pair.
That's why I never taught them to read. It can only end in trouble.
Originally posted by Wolf View PostYep,still going....
The new HE are for a smaller ox for sure.
You could get an Ultimax in there though.....
Originally posted by fpitas View PostSheesh, my RSS390HF-4s are pushing ten years. I hope they don't read this thread
Yep,still going....
Houston we have separation... between the cone and voice coil. You can imagine how great it sounds when the voice coil jumps out and slaps an aluminum cone. It looks like the connection at the back of the cone is pretty battered, I swear everything was all together when I I checked the other day.
Wolf, great to see you are still around. I don't recognize anyone else from when I frequented here.
This is in a just shy of 5CF sealed box packed pretty good with sound dampening material, does anyone have any experience with the new Dayton high excursion reference series? I am looking at the RSS390HE-22 , Dayton is suggesting a box much smaller than I what I have.
I edited my post to show the sprung coil possibility, and it still shows when I hit edit. Not sure why it's not showing up when saved.
If it sounds springy or like a loose wire when pushed, adjacent to Blenton's note, then it's exceeded its thermal max and is toasted and done.
