$1 aurasound drivers in an array?
  • #16
    Re: $1 aurasound drivers in an array?
    Originally posted by [email protected] View Post
    Have a look at rcarpenter's Sony line array for insperation
    Exactly what I was thinking about. It looks like r-carpenter was setting up an open baffle design, does that often go hand-in-hand with line arrays or is that dependent on the speaker?
    • #17
      Thanks, arlis
      just like with conventional speaker, it depends on the driver/objective. You can do sealed, ported or various open baffle designs. All offer benefits and disadvantages on their own.
      Anyway, all these Aura drivers can be used but can be used differently. 3" to 4" size mid-woofers are best used for a simple two way line array. Full range array will need lots of high frequency compensation and using a tweeter/s is just easier. Larger drivers will suffer too much HF loss to be used successfully as a full range or in two way. Size of an array itself makes a difference too.
      I still see a Line Array as a superior way of faking live performance tho.
      http://www.diy-ny.com/
      • #18
        I wonder how hard it would be to mate those auras with a small array of piezo horns to cover the top end. There's plenty of those to choose from for pretty cheap, and if they're not pushed too low would probably be pretty good tweeters.
        My modest builds:
        Armadillo TM, A.K.A. Lil' Dillo
        Tarkus/Armadillo build #2
        Armadillo Center Channel
        Au-Rock-O Sub
        Tarkus
        Staining MDF tutorial
        • #19
          I ran DATS through a few of the 3" driver the OP mentioned in his first post. They were within about 5% of eachother, and this is what I came up with:
          Re - 13.578 Ohms
          Fs - 169.6 Hz
          Qts - 1.374
          Qes - 2.176
          Qms - 3.729
          Le - 0.853 mH
          Mms - 1.353 g
          Vas - 0.0264 cu ft
          I used the added mass method to find the Vas, so hopefully it's close. I'm thinking about throwing one on a simple U-Frame and getting an FR using Holm. Depends on how warm it gets later.
          RYAN N.
          "Why do you have the stereo on while you're watching TV?" - "....Cause I like to party."
          RSS390HF Build - http://techtalk.parts-express.com/sh...d.php?t=224998
          AviaTrix Build - http://techtalk.parts-express.com/sh...d.php?t=230372
          Wolf's PC Speakers Build - http://techtalk.parts-express.com/sh...84#post1838384
          Overnight Sensations MT Build - http://techtalk.parts-express.com/sh...ation-MT-build
          • #20
            Originally posted by jhollander View Post
            I’m not as excited if I have to do a tweeter and woofer/ sub. That’s just me (lazy).
            May be these at $2 for 30
            I bought a case of these. If I ever get healthy enough to work on 'em I'm planning an 8 -12 driver array with face trimmed piezo's in an array. More likely to be used for "portable" PA work with a BFM sub. Rear mounted drivers in a vented or TL enclosure. Should get down to 75-80 hz. Lightweight. The paper cones would be my big concern, so I'd design with spares in mind. Kind of a bfugly gray/green if that matters to you.
            Lou's Speaker Site [speakers.lonesaguaro.com]
            "Different" is objective, "better" is subjective. Taste is not a provable fact.
            Where are you John Galt? I may not be worthy, but I'm ready.
            • #21
              Has anyone considered using one or more of these?
              I have no idea if it is any good or not. I just thought it was a awesome looking tweeter.
              What do the line array gods think?
              Kevin
              Shaken, not stirred...
              Classix II
              OS MTM's
              Digger 8 sub
              Overnight Sensations Center Channel
              Sprite Build
              Wolf's PC Speakers
              Minions III with Voxel Sub
              • #22
                Originally posted by LouC View Post
                I bought a case of these. If I ever get healthy enough to work on 'em I'm planning an 8 -12 driver array with face trimmed piezo's in an array. More likely to be used for "portable" PA work with a BFM sub...
                Lou, I'd love to see your take on an array.
                John H
                • #23
                  Me too. I just ordered 50 speakers @ $1.00 each. I've got a few tweeters lying around, so I'll need some help in that area. And you can count on me asking a lot of questions.
                  So... here I go with questions.
                  1. How many should I use per side? I don't want to throw a lot on a baffle just because I have them. I'm wondering if there's a rule of thumb as to how many drivers a guy should use in a case like this.
                  2. I'd like to wire this as an 8 ohm nominal load. I can figure out how to get it to 8 ohms, but is there a systematic way rather than just putting them in a series/parallel configuration that comes out to 8 ohms?
                  3. Some of you guys mentioned getting them down to 80 Hz. I played with them in Unibox and WinISD and can't get them lower than 100 Hz. How did you get to 80 Hz?
                  4. This might be effected by the previous question, but sealed, vented, or open baffle?
                  As it stands right now, I'm going to try to rear mount them so I can get them flush and for aesthetics. Any comments or suggestions? I don't know if I'll use a hole saw or my router to cut the holes. I know I'll have to do some routing to get them flush with the surface of the baffle.
                  I'll post pics as I build.
                  Thanks for the replies thus far,
                  Mike
                  "We're speaker geeks, not speaker nerds. Nerds make money!" Marty H
                  Bismarck, North Dakota
                  My Current System: HiFiMe DIY T3 Amp, Kenwood Basic C1 Preamp, and Paul Carmody Sunflowers
                  My Garage System TPS3116D2 Amp, DIY PS 95 Speakers, DC 130 Sub
                  • #24
                    Mike,
                    I’ve not done (a real) one but Jim Giffin’s white paper “Design Guidelines for Practical Near
                    Field Line Arrays James R. Griffin, Ph.D.” will give you a good start.
                    Don Keele of CBT fame has good information on wiring multiple drivers for shading (reducing the output) of the outboard (for lack of a better word) drivers. CD1, Keele Poster 4 CBT30
                    And of course there’s John Murphy’s Corner-Line-Array PDF document which is good reading for the height.
                    These seem similar to the NS3-193 so IMO the easiest way to mount these is a hole saw, rear mounted on ½ inch mdf with a ¼ inch round over.
                    You’ll need to figure out where are you going to put these, active bi amp or passive. That should help to narrow your design. It would be good to measure these to see where the break up starts.
                    John H
                    • #25
                      Mike,
                      Thanks John. I have Jim Griffin's paper and I downloaded Don Keele's. I'm looking at John Murphy's web page right now. I'll probably set these up so I have the option of bi-amping them. That will provide a little more flexibility.
                      Thanks again,
                      Mike
                      • #26
                        I'm not sure which of the numbers would translate to Xmax, so I figured I should ask. It seems to me it would be the VC winding length or the magnetic gap depth. Am I close? Also, I don't see Le listed. Is it as simple as measured the inductance of the voice coil?
                        Thanks,
                        Mike
                        http://www.madisound.com/store/manuals/ns3-194-16a.pdf
                        • #27
                          Re - 13.578 Ohms
                          Fs - 169.6 Hz
                          Qts - 1.374
                          Qes - 2.176
                          Qms - 3.729
                          Le - 0.853 mH
                          Mms - 1.353 g
                          Vas - 0.0264 cu ft
                          Thanks Ryan!
                          • #28
                            Thanks,
                            Mike
                            Wolf once told me it would be the magnetic gap height-the VC length. So in this case 8.4-7.2= 1.2mm Xmax... IIRC...
                            HAGD,
                            Marc
                            Even though I try to tell everyone upfront, understand that I am still a Newb. I wish the status of Seasoned Veteran/Senior Member, etc. was earned with time not posts...
                            TMWW thread
                            Maurbacs DCR Tower
                            • #29
                              Thanks Marc.
                              • #30
                                Damn.... I bought a case of these when they were 1.50 $ each.
                                Figures they would discount them.
