Re: $1 aurasound drivers in an array?
Mike, model diffraction response in Tolvan diffraction modeler. It'll give you an idea of how many drivers you want to use in array. The taller the array, more issues you will have to deal with and more complicated filtering will be needed. But also, more efficient it will become with less distortions. After you decide, how big it is, you can look in to filtering options. 3" Aura has a clean mid-range and it'll shine in the array.
High Qts lands in to a open baffle configuration. Is it going to be wide baffle, U-pole or narrow baffle dipole, is up to you. Impedance of an array is easy enough to adjust by series/parallel wiring.
Before getting in to shaded arrays, curved arrays and so on, try to do it step by step and resolve the simple issues. I don't mean to sound condescending, it's just frequency response of an array is not formed the same way as a conventional loudspeaker.
