Re: ~ 5" Coaxial drivers?
is 5" a must the Seas T18RE is a nice speaker, i have one from the loki kit from madisound
Originally posted by Pallas View PostShoulda just called me. I could have sent you one. I'm using three Q100's up front temporarily at home (in addition to two for background music in the bedroom), which means I have a spare.
Originally posted by Pallas View PostAlso the neo motor, and the 3001 has a plastic basket whereas the Q100 has an alloy basket. And the cone material is different; the 3001 has a plastic-looking collar and then a paper cone. The Q100 has a metal cone. (But one of the best-controlled ones around, especially considering the price.)
Not quite. Remember that the 3005 KEF eggs are "full range" little speakers. As a practical matter, they go down to about 120Hz. And they're fairly inefficient. Not dedicated mids, really. And the HTC3005SE (I'm using two of them as side-surround) "center channel" is not a 3-way design but a 2.5-way design. (They claim both in different places but after tracing the xover it's clearly a 2.5-way.) I don't know if the driver part number is different.
Looking at the center, it certainly seems more like a 2.5 way than a 3-way.
Originally posted by Pallas View PostIn the DIYA LS50 thread, Jack commented that the thin surround of the 3001 was the transition to the Z-surround.
Originally posted by Pallas View PostI wonder the context for that. I can think of way more than three. Maybe he just meant three 5" midwoofers?
In the latest generation, there are 5 platforms: the 5" midwoofer (Q100/R100/LS50), 5" midrange (R300+), 5" flagship midrange (Blade), 6.5" midwoofer (Q300/Q700), and 8" midwoofer (Q900).
And then the older ones (the 6.5" Reference midrange, the 3" one in the 1005-series, the 4" one in the 2005-series, and the 4.5" one in the 3005-series). And the in-wall ones, etc. So there are a lot of Uni-Q's.
I’d love to get my hands on all the different Uni-Q drivers. I’m curious how tiered in performance the drivers are relative to the cost of the speakers they come as part of.
Originally posted by Pallas View PostAt any rate, I'll be back in a couple weeks. We're going abroad tomorrow. And coming back with new rings on our fingers. Cheers.
Erin why no love for the b&c? The de7 compression driver is small-. 75 inch so off axis would be good. I have a de5, which is the .5 inch one and it sounds really good. Plus b&c has solid engineering and factory data. The voice coil test the other month would ha e the off axis data too.
Originally posted by ErinH View PostI saw the thread on diya regarding the LS50 where Jack briefly highlighted the differences in drivers. I, too, would like to get my hands on the R100 and LS50 drivers to see how comparable they are as we know one difference in those and the Q100 is the shorting ring, among other things. Unfortunately, spending $850+ on a set to gut those drivers is too far beyond my willingness to experiment. :(
Originally posted by ErinH View PostMy main reason for purchasing them is, as you said, to see how the suspension performs while under test on the Klippel LSI.
Originally posted by ErinH View PostThe main difference I see between it and the 3001se driver is the Z-surround.
Originally posted by ErinH View PostOn the flip side, I do recall reading the Z-surround design was intended to help the tweeter response by keeping the profile of the surround down; the hts3001se doesn't have this.
Originally posted by ErinH View PostBut, then again, maybe the HTS is intended to be crossed low enough where excursion isn't of concern (kind of makes me wonder why a reverse surround wasn't used but I'm certain it was considered). *** Though, it's just an educated guess. As you mentioned, the ht3001se has a wider response angle which is just another reason I imagine it's intended use is as a midrange.
Originally posted by ErinH View PostInterestingly enough, I recall Jack mentioning there are only "3 Uni-Q" drivers and he noted them by size. He didn't mention the 4.5" size which is used in the HTS3001se. Is it not considered a Uni-Q?
Originally posted by ErinH View PostAt the price of the Q100, IMO, given the performance Zaph documented,the speakers seems like a great value. Even then, if you were to gut the speakers for the drivers themselves you have 2 pair of tweeter and midwoofer for about $450-550 (used - bnib).and of course the cost.
If you have the space, Q100s make excellent desktop speakers.
Hey, Jay. I knew/hoped you'd chime in sooner or later.
I believe the Q100 is indeed larger than I can make use of. That said, I found a good deal for the bookshelves on ebay ($385 shipped) and figure at the least I can sell them to someone who can make better use of them. My main reason for purchasing them is, as you said, to see how the suspension performs while under test on the Klippel LSI. The main difference I see between it and the 3001se driver is the Z-surround. Also worth noting is the ht3001 driver has a ribbed cone while the q100 does not. I would guess this is a hint at it's intended use/design as a midrange with the cone designed to alleviate breakup. On the flip side, I do recall reading the Z-surround design was intended to help the tweeter response by keeping the profile of the surround down; the hts3001se doesn't have this. But, then again, maybe the HTS is intended to be crossed low enough where excursion isn't of concern (kind of makes me wonder why a reverse surround wasn't used but I'm certain it was considered). Though, it's just an educated guess. As you mentioned, the ht3001se has a wider response angle which is just another reason I imagine it's intended use is as a midrange. I'm just curious how well controlled it is and if it's the same/similar to the Q100 driver. Of course, you can probably determine this simply by looking at the size of the speaker/driver itself. The R100 seems to use both these aspects (radially ribbed, z-surround). As noted, the R100 is told to have a shorting ring as well which should help on high frequency distortion over excursion (IMD). Interestingly enough, I recall Jack mentioning there are only "3 Uni-Q" drivers and he noted them by size. He didn't mention the 4.5" size which is used in the HTS3001se. Is it not considered a Uni-Q?
I do intend to use the drivers actively (assuming they pass my criterion). However, I will test passively as well. If they perform well and I don't feel an active setup is necessary, I'd have no problems using them passively.
I've reached out to Kef in regards to obtaining test samples. As well as the Q100 driver did in Zaph's tests, I think it's worthwhile for the audio community to see further independent testing. At the price of the Q100, IMO, given the performance Zaph documented,the speakers seems like a great value. Even then, if you were to gut the speakers for the drivers themselves you have 2 pair of tweeter and midwoofer for about $450-550 (used - bnib). Given the performance, this still seems like a solid option as separate drivers; then you factor in the benefit of the concentric design and it's a double bonus. If the others perform as well, I think Kef would stand to gain a lot of good press from the testing. For instance, look at all the people interested in the Q100 based on Zaph's test. That alone prompted me to purchase the Q100 & HTS3001BL. I spoke with a rep for the company and his take was that they are simply trying to keep driver replacements in stock for customers who own the speakers. Which is reasonable. But there's no reason production can't be ramped up. ;)
Bottom line: I've made the purchase. I'll be testing. Sucks I had to go to the extremes I did but I definitely look forward to the results. If they perform as well as I hope, I can see these being used in a future setup for car/home.
Originally posted by ErinH View Postunfortunately finding off axis response of those isn't easy.
I bit the bullet and just pulled the trigger on both the Kef Q100 and the HTS3001SE speakers. Not sure if either will fit, but the only way to know is to gut the speakers and see for myself. May post the data if I find the time. Based on what Zaph found with the Q100, I'm at least hopeful the 4.5" in the HTS3001SE will perform similarly, seeing as how the Q100 probably won't fit.
It would be cool to see what the Z-flex suspension on the Q100 driver does on the Klippel.(Also, how well inductance is controlled over its stroke, despite not using shorting rings in the motor; the major differences in the "step up" R100's driver are shorting rings in the motor and obviously the radially-ribbed cone. According to KEF's Jack Oclee-Brown the LS50 driver also has some tweaks to the magnet in addition to that awful rose-gold coloring.)
The size of the magnet on the Q100 driver (compared to earlier KEF Q-series drivers) suggests to me that it was originally designed around a neo motor, but then neo prices skyrocketed so they had to go back to ferrite. The 3001SE driver has a neo motor.
FWIW, here's a picture of the HTS3001SE crossover (egg opened up because, as you can see, one of the chokes came loose in shipping; this was a return from one of my KHT3005SE sets, sold on eBay).
Fairly complex for such a small and relatively inexpensive speaker of that finish quality.
The Q100 crossover is much simpler: single air core inductor, single poly cap, single resistor.
In this rough size-class (a bit bigger, because of the frame lip) there's also the Pioneer EX concentric. (See avatar for a cutaway.) But it's frightfully expensive in comparison. Perhaps (debatably, which I write having both drivers in hand and having commissioned cabinets that use the Pioneer driver) worth it for home, but I wouldn't waste it in a car.
ErinH, heard the seas in a german design that was around 45000.00. price is crazy, but speaker had a couple of woofers in the cab also. have to say that i was blown away. one of the best soundstages i have ever heard. just a very impresive speaker.
Originally posted by Whitneyville1 View Postwww.apexjr.com has the Vifa 120mm (nominal 5") coaxial they call for a .14 cu. ft. ported enclosure for 80-20,000Hz, 87dB/W 8 ohm 50 watt max.
They show a generic cross-over with an L-pad on the tweeter. They go for $15 each. I messed around with the woofer in WinISD Pro and I think 65Hz is doable with a +/- 3dB ripple passband. It looks like their XO crosses pretty high, maybe 5K, but it's both 2nd order and I think you can do better. Not a big investment to play around with.
I just found this at PE - Visaton 4800 FR13 5" Full-Range Speaker 4 Ohm
*my wife is going to kill me*
The BMS is nice.
BMS also have a 5CN140 too. A simple cap up high should EQ that guy pretty flat and give you a sharper roll off down low.
Durwood over on the car forums is using the CN140s in his car.
B&C has a 5" coax too if you are in the pro audio market. Vance has tested either the 5 or 6 in a recent Voice Coil too.
Originally posted by Face View PostThe Q100's driver itself is just under 5", but with just under 6" including the frame.
As far as selling for repairs only, KEF probably gave them a spanking for selling so many drivers to DIY'ers. I wonder if AJ has anything to do with this too...
Yea, kinda figured that's what happened. Sucks. But thanks for that information. I see they offer a 5" driver on the r300 series. Maybe that's something I can pursue. But, I'll not count on it.
Originally posted by GranteedEV View PostBMS 5CN160 - for an active crossover you still might want to put an L-Pad on the tweeter to lower the noise floor, since it's ~100db/w or higher.
