Has Anyone Seen the New Kits Lineup at DIYsoundgroup?
  • #31
    Re: Has Anyone Seen the New Kits Lineup at DIYsoundgroup?
    Originally posted by jasonb View Post
    I like the idea of the whole Econowave line but the 8" versions excite me the most since the baffle isn't much larger then what you would see on a typical 7" two-way but the sensitivity and maximum output are much better. Jeff, any chance you would ever consider an 8" 2.5 way TMM in the from of a small tower keeping the same 9 1/2" baffle width? It wouldn't take up any more floor space than the 8" 2 way on a stand but the performance might be closer to that of the 12" 2 ways.
    Jason
    just thinking aloud here, but an 8" 2.5 way using professional high sensitivity drivers most likely won't dig very low due to the driver's design...go with an 8" sub (or even 10-12" side firing) to anchor the bottom of your 2.5 way, and you'll have a big sensitivity discrepancy between the bottom end and the top end....also, you may get some expensive crossover parts as you try roll the .5 woofer off in the sub 300hz range...
    is take one of the 8" designs here, and develop a tower version, with an additional 1.25-2.25 cubic foot of volume (while maintaining the original speaker's baffle width) that would incorporate the hardware from one of Eric's subwoofer kits, and side fire the sub.....make the bottom end with the subwoofer amp, and use the subwoofer amp's active crossover to cross to the top end, much like the recent Polk LSi9's or the older Acoustic Research 315HO's and AR3 and AR1 Hi Res...
    • #32
      Originally posted by Jeff B. View Post
      I haven't named it yet, just started to do some crossover work. Anyone have any suggestions for a good name?
      Jeff
      Ryan - Yes, it is the Beta 8-A - a pretty stout 8" driver.
      How about the BetaWave-8?
      -Dan
      Mandolin Curved Cabinet Floorstanding; Dayton Reference 18" sealed Subwoofer; Sealed 12" Dayton Reference Subwoofer ; Overnight Sensation builds
      • #33
        Originally posted by Face View Post
        Check out the breakup just over 2K, the SEOS 12 may be a better choice with this woofer anyway. FYI, I'm using SEOS 12 waveguides with 10" AE TD10M woofers and there are no issues with the large waveguide.
        I was thinking more about aesthetics with the 10" waveguide.
        http://jaysspeakerpage.weebly.com/
        • #34
          How well to the Eminence drivers test? Distortion and stuff?
          • #35
            I just saw that Erich has more baffles posted now: http://www.diysoundgroup.com/speaker-baffles.html I wonder if he has flat packs for all of them?
            I would love to have one of the 12" woofer kits in a tower as the LR mains. If he offered a complete flat pack then I could start saving now!
            Kevin
            Shaken, not stirred...
            Classix II
            OS MTM's
            Digger 8 sub
            Overnight Sensations Center Channel
            Sprite Build
            Wolf's PC Speakers
            Minions III with Voxel Sub
            • #36
              http://www.diy-ny.com/
              • #37
                and this one
                Greetings, After a successful SEOS build for my mains: http://www.avsforum.com/t/1417294/seos12-2512-build , it's time to start the build for the side surrounds. As background, my original setup was an aging Paradigm 5.1 system. I replaced the front LCR speakers with SEOS12/DNA-360/2512...
                https://www.youtube.com/channel/UCm2...oSKdB448TTVEnQ
                • #38
                  Yeah I'm not a fan of the woofers being smaller then the WG, sorry...
                  • #39
                    I'm not sure a 2.5way makes much sense with these. The baffle step point is a little lower than normal. I found with my alpha8a design (I posted a pic a few posts back) that baffle step was easily accounted for in the cross over. 2.5ways add a lot of complexity for not much gain. The alpha8a does dig nice and deep, though a little lumpy, considering what it is. I suppose in a tower with lots of volume, 2 of them would likely make really good bass. And you could go very loud. I used mine sealed with subs.
                    • #40
                      Kevin
                      There are flat packs for every speaker kit. I just haven't uploaded the photos for the SEOS models yet. They should be up by Monday.
                      The Overnight Sensation cabinets and kits will be back in stock in less than a week.
                      • #41
                        You sir are a steely eyed missile man! ;)
                        Kevin
                        Classix II
                        OS MTM's
                        Digger 8 sub
                        Sprite Build
                        Wolf's PC Speakers
                        • #42
                          LOL... thats what you said about the OS MTM's a month ago Erich.. missed the 3 sets we wanted to give for Christmas presents...
                          • #43
                            Nah, I sent the last pair out 3-4 days before Christmas. I was worried if they would arrive in time. If they were out of stock before that, it might have been because PE was out of a crossover part or something. But it certainly hasn't been a month my friend.
                            I've spent the past 2 weeks getting all these new kits uploaded, photos taken, crossover parts, baffles, flat packs, shipping boxes, etc, etc. Plus I test every compression driver before they ship. And finalizing subwoofer boxes. I thought I did pretty good with about 20+ designs. :D So something had to take a hit, and it happened to be the OS MTM's!
                            But seriously, they will be listed very soon. Same with the subwoofer flat packs. Those were difficult and time consuming because of all the different designs everyone wanted. I've got some already, but haven't had time to update the site or get new photos.
                            I know there will be 1cuft, 1.25cuft, 2cuft, 3cuft, 4cuft, (all sealed) and then at least 2 designs with passive radiators. 2 designs are dual opposed. 1 design has dual 12's mounted in a taller slender box. I'll work on the ported models later.
                            • #44
                              I am working on a new 8" two-way with waveguide kit that will be reasonably high efficiency in a small box and will surprise you on what it can do. Originally intended for side and rear applications a lot of people will use it for front mains too, especially along with a subwoofer. I will post pics later.
                              I'm probably not alone on this, but given the wide variety of choices for these designs, I would be very interested to hear what you think the differences are between the 8" and the 12" versions you've done (or any of the other designers for that matter) once you've finished.
                              What would be the tipping point where you'd say, 'yeah, I really need the tempest'. Is it power handling? Is it SQ? Off axis response?
                              • #45
                                Sound quality was obviously the biggest criteria. None of the designs are bad at all, even the lowest cost models. If they weren't really good, they wouldn't have made it to kit form. Some designs were done that just didn't fit in, so we didn't use them. I thought it was a good idea to have 3 price structures just so people had options based on their budget. None will disappoint. Heck, I have the Karma-10 in my living room.
                                I'll try to go into more details later, but I'm not much of a salesman, I just help make the kits available. :D
                                If I had to quickly describe it, I would say the Karma Series was specifically designed to keep the price very low while still using good name brand parts. A lot of time was put into these to make them sound really good with just enough crossover parts to get there, while keeping the cost low.
                                The Fusion Series and Alpha Series would both sound great and they're very similar. I simply broke those designs into 2 groups based on price so it was easier to compare. The price difference is mostly due to the woofer.
