Ok, so I'm using my laptop -> REW -> Blue Icicle -> Cross Spectrum Dayton EMM-6 and I'll be most likely be using one of my AMP-100s to power them. I've built a TALL (I think it's about 7 or 8ft) speaker stand out of 2x4s (it's uber sturdy) and when I did the initial Deadhorse measurements they were really clean to about 200hz or so.
Now, what I'd like to do is get clean measurements from the bottom (F3 of the new design is about 95Hz, so an octave or 2 lower than that) all the way to the top, 20kHz and I would also like the spl measurements to be absolute.
So I'll need to first adjust the amplifier to output 2.83v, correct? So how do I go about doing that?
Next, I'll need to take nearfield, midfield, and farfield measurements. Do I do the farfield first, then correct the volume levels or adjust the FRD later? Oh yeah, and some horizontal-plane off-axis measurements, too - advise on that as well.
And finally I'll need to take a measurement of both drivers together to ascertain my "z" measurement.
I'm thinking I'll build an attachment that can hold the mic at the 3 intervals, and at a predetermined angle, at the same time. Wheels are done spinning already - probably make that this weekend.
Basically I'd like to make some measurements that are "as professional as possible" with my setup.
Thanks in Advance!
Thanks in Advance!
