So I have a emotiva mini x amp and I may be crazy but it seems to sound a lot better if I have my ps3 hooked directly to it using rca's rather than through my pre/pro. The only problem with doing this is that the volume knob ( Think it acts more as a gain knob?) is too sensitive. When at low volume the channels don't have even output. When turned up it all evens out. Is there a way to adjust this? I think I read about a similar problem with the little dayton amps a long time ago.
Amp volume knob problem.
Re: Amp volume knob problem.
Typically, it's the pot itself. Low quality pots will have uneven tapers, giving the problem you're experiencing. You could open it up and see if there's space for a higher quality pot like an Alps RK27.
EDIT: Before opening it I'd try calling Emotiva, and see if they have a fix."I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Originally posted by killa View PostSo I have a emotiva mini x amp and I may be crazy but it seems to sound a lot better if I have my ps3 hooked directly to it using rca's rather than through my pre/pro. The only problem with doing this is that the volume knob ( Think it acts more as a gain knob?) is too sensitive. When at low volume the channels don't have even output. When turned up it all evens out. Is there a way to adjust this? I think I read about a similar problem with the little dayton amps a long time ago.Dave
If you can read this, thank a teacher.
If you are reading it in English thank a Veteran.
Originally posted by AJ View PostTypically, it's the pot itself. Low quality pots will have uneven tapers, giving the problem you're experiencing. You could open it up and see if there's space for a higher quality pot like an Alps RK27.
Originally posted by dthomas View PostSounds like you have a bad volume pot on the amp. This is an integrated amp so having a preamp could cause you to overdrive the amp's input which explains why it sounds better with out it. But the non linear adjustment sounds like you got a problem with amp's preamp circuit or the volume pot itself.
Originally posted by killa View PostI am pretty sure it is just the pot as it sounds fine at higher volumes but sometimes people are sleeping so it needs to be a little quieter. Would overdriving the amps input cause it to sound compressed/less dynamic range?
If it is out of warranty replacing the volume pot is a simple fix. Just need to ascertain the type of pot you have. Emotiva could probably help you out.Dave
Originally posted by dthomas View PostSure overdriving it would cause the preamp section to have no headroom left (compressed and lacking dynamics). Integrated amps like the emotiva don't need a preamp and there is probably a limit to how much voltage they will take on the input. Usually only .7 to 1V P-P is all that is required to drive them to full power. A good preamp could easily put out 5V or more so yes the preamp was probably an issue.
I assume the voltage is related to the volume so at lower volumes it wouldn't be overdriven as easily?
Originally posted by killa View PostI was just thinking when I have my preamp hooked up I have the volume knob on the amp all the way up. Could this cause any sounds issues?Dave
