Since we had a recent thread talking about small subs, I thought I'd spill the beans on my latest project. I just ordered a Dayton RSS460HO-4. This is an 18" Dayton Reference Subwoofer driver that weighs 42 lbs! Although I like the HF series quite a bit, the large size of the 18" driver offsets some of the "negative" attributes of the HO series for home theater, and it also can handle quite a bit of power.
Here's the Parts Express Link
One of my favorite movies to watch sonically is Tron Legacy. It's kind of a stupid movie, but I love the soundtrack. Unfortunately the bass is too much for my current 12" sub to handle, so I quickly started making plans for something bigger, something that could handle the punishment of a -5 dB playthrough of TL.
Pertinant (published) data:
1164 cm^2 SD (more than 2 12" drivers)
12.75 mm Xmax*
Fs: 19.6 Hz
Sensativity: 89.2 dB 1W/1M
*This driver has been tested independently by at least 2 people. Data-bass tested it with very good results, and they calculated the Xmax to be 18-20mm. Stereo Integrity paid someone (not sure who) to test this driver and they reported 16mm Xmax- keep in mind they are a competing company and would want to downplay any competing products.The Xmech is very close to 30mm one way. Data-bass reports that in a sealed enclosure 75V did not bottom the driver. (I think that's about 1200 watts?) HERE'S the link to the Data-bass review
Anyway, currently plans are a 4.0 Cubic foot net sealed enclosure with a double-thick front baffle and excessive bracing. It will be 27" H x 20.5" W x 19" D. It will be a passive sub with a recessed speakon connector. Powered by 1/2 of a Behringer iNuke 3000 DSP. I will not be running a dedicated HPF on this sub, so the amp-limiting 10 Hz HPF will be in effect.
If my calculations are accurate, it should be capable of 116 dB at 60 Hz, and 105 dB at 20 Hz with 600W, which should be just shy of Xmax. F3 will be around 34 Hz, although with the Parametric EQ I could easily lower the F3 to the mid 20s.
As far as I can tell, no one has posted a build of this sub yet on Tech Talk. Useage will be Movies, music, and video games.
12.75 mm Xmax*
Fs: 19.6 Hz
