Crosstalk measurements between inductors
Re: Crosstalk measurements between inductors
"Dennis arbitrarily used a 26-kHz signal"
Why would anyone use 26 KHz? Did you mean 2.6 KHz?
The crosstalk is a function of current
and, obviously, inductor impedance rises with increasing frequency and therefore
the current decreases. It would be more reasonable to build a "typical" tweeter
crossover with one inductor. Something like 8 uF input, that .3 mH shunt and a 6
ohm dummy resistive load. Short the 8uf to ground to simulate the low source
impedance of the amp, and measure across the 6 ohm resistor. That would be the
sense circuit.
Some thought should be put into the driven circuit. Worst case is probably the
inductor in a midrange circuit with the most current flowing, perhaps the HP section.
Perhaps we should look to real world cases, such as the B&W 801 woofer to mid
crossover where there have been reports of significant crosstalk.Last edited by Pete Basel; 03-02-2013, 09:49 PM.
Nope, I did not mean 2.6 kHz. I wrote what was printed in the article, and in his testing of the ferrite (1.7 mH) and steel laminate (5 mH) inductors, he used frequencies of 4 kHz and 100 Hz respectively, all frequencies chosen "simply for measurement convenience". My goal was to reasonably replicate the tests and results documented by Dennis in his article as explanation on why I keep telling people that a 2" spacing between air core inductors is quite adequate, not requiring the inductors to be stood up or rotated. I believe I accomplished my goal, and while I'm sure others will suggest a "better" way, I don't think the basic results will change in any significant manner. Perhaps the B&W crossover you referenced had some serious flaws regarding component placement/orientation?
Originally posted by Pete Basel View Post"Dennis arbitrarily used a 26-kHz signal"
and the obviously inductor impedance rises with increasing frequency and therefore
sense circuit.
Possibly stupid question, does the geometry of the coils being tested play a role here. The blanket rule of thumb here is 2" but does that apply to coils 1" in diameter the same as those 3"? Just have to imagine the resulting magnetic field is dependent on the size of the circle of electrons driving it?
You cannot make blanket generalizations. If the same inductor is used in
a different application with 10X the current then the field strength is 10X.
I'd say take the results as a rough guideline.
Also, let's say that at some low frequency we have 40 dB of attenuation
in a tweeter circuit, coupling in that range will cause more of an issue
since a tweeter cannot handle much LF energy. It depends on many factors
so, keep the guideline in mind but also think about the consequences of
coupling. The simple thing is to place inductors in the corners of a board to
provide the maximum distance; why do it any other way?
Originally posted by Paul K. View PostNope, I did not mean 2.6 kHz. I wrote what was printed in the article, and in his testing of the ferrite (1.7 mH) and steel laminate (5 mH) inductors, he used frequencies of 4 kHz and 100 Hz respectively, all frequencies chosen "simply for measurement convenience". My goal was to reasonably replicate the tests and results documented by Dennis in his article as explanation on why I keep telling people that a 2" spacing between air core inductors is quite adequate, not requiring the inductors to be stood up or rotated. I believe I accomplished my goal, and while I'm sure others will suggest a "better" way, I don't think the basic results will change in any significant manner. Perhaps the B&W crossover you referenced had some serious flaws regarding component placement/orientation?
Originally posted by Paul K. View PostPerhaps the B&W crossover you referenced had some serious flaws regarding component placement/orientation?
Go read the full article that Dennis wrote and you'll see that it covers a lot more than what I was replicating, including larger inductors, both physically and in inductance, and different frequencies. Obviously, as I've said at least twice (in this thread and my other thread about mutual inductance) if you have the room, then by all means spread out the inductors as far as you want. If room is limited, then you'll need to orient them appropriately to minimize both mutual inductance and voltage crosstalk. There's an in-between scenario that I suspect occurs frequently, and I have absolutely no problem with a 2" spacing for air-core inductors laid down flat.
In my testing, as I stated, I measured the crosstalk at 5 different current levels in the circuit with the two coils' spools touching and got the same amount of crosstalk in terms of dB or percentage. Obviously the amount of signal coupled increases with increased current, but the amount coupled still was only ~1.7% regardless of current level. With the two inductors spaced at 2", the amount coupled dropped to ~0.2%, which is insignificant IMO.
Paul
Originally posted by Pete Basel View PostYou cannot make blanket generalizations. If the same inductor is used in
Yes okay I think we are pretty much in agreement. What you are saying
is that for air core inductors the coupling is linear by pointing out the constant
percentage. This makes sense since air cores are linear by nature.
My point about current level, is that the inductors with more turns and more
current, such as the woofer inductor may have different requirements due to
the stronger fields than those with significantly lower current. Or perhaps the
inductor in a poorly designed trap, where the system impedance dips low
indicating that the current is high as is seen in some commercial designs.
That inductor would have a much stronger field, not that anyone here would
make such a mistake.
Yes, we now agree on the primary point I was trying to make. I can run another set of tests but using a pair or larger inductors (in size, number of turns and inductance), as well as a test pitting a large inductor against a small inductor. I have time tomorrow and might do it or maybe you could do it instead?
Paul
Originally posted by Pete Basel View PostYes okay I think we are pretty much in agreement. What you are saying
I ran additional tests today that reasonably simulate, I think, crosstalk effects between large and small inductors, like between a woofer crossover inductor and a midrange or tweeter crossover inductor.
Connected in series to the output of a power amp were a 4-mH inductor and an 8-ohm resistor, with the resistor representing a driver. The power amp input was driven by a sine wave at 250 Hz from my signal generator. For the "pickup" inductor to "receive" the field radiated from the driven inductor, I used two, one an identical 4-mH and the other with a 0.3 mH value. I measured the crosstalk in both pickup inductors at two power levels into the 8-ohm resistor, 1 watt and 10 watts, and with two spacings between the driven and pickup inductors, touching and 2". For each set of conditions, I measured the voltage across the driven inductor and the pickup inductor, then calculated how much the voltage in the pickup inductor was in terms of dB and percentage compared to the voltage in the driven inductor. Of course, all coils were air-core and both driven and pickup coils were laid down flat on one of their spools caps. Voltages were measured with my Fluke 8050A True RMS DMM.
Using a 4-mH pickup inductor, at 1-watt and zero distance, the crosstalk voltage in the pickup inductor was 2.3% or -33 dB of that in the driven inductor. Increasing the spacing between inductors to 2", the crosstalk voltage was 0.28% or -51 dB. Increasing the power to 10 watts, at zero distance the crosstalk voltage was 2.2% or -33 dB. Increasing the spacing to 2", the crosstalk voltage was 0.28% or -51 dB.
Using the 0.3-mH pickup inductor, at 1-watt and zero distance, the crosstalk voltage was 0.48% or -46 dB. Increasing the spacing to 2", the crosstalk voltage was 0.05% or -66 dB. Increasing the power to 10 watts, at zero distance the crosstalk voltage was 0.47% or -47 dB. Increasing the spacing to 2", the crosstalk voltage was 0.05% or -66 dB. Note that I rounded off all of my calculations to just two significant numbers simply for convenience in this report.
I'm not sure what you might conclude from these tests. I do note than when the pickup coil is much smaller than the driven coil, the crosstalk voltage is much smaller in it than when both coils are the same, whether both are 4 mH that I used in today's tests, or both are 0.3 mH from my previous tests that initiated this thread. Using a 10-watt input and a spacing of 2", with a pair of 0.3-mH coils the crosstalk measured -54 dB/0.2%, with a pair of 4-mH coils it measured -51 dB/0.28%, and for a 4-mH/0.3-mH coil combo, the crosstalk measured -66 dB/0.05%. The other interesting outcome is, that, the amount of crosstalk between similar inductors (identical in my case), whether large or small, is pretty consistent. With a 10-watt input (to the 8-ohm resistor) and a spacing of 2", a pair of 4-mH inductors had crosstalk that measured -51 dB/0.28%, and a pair of 0.3-mH inductors had measured crosstalk of -54 dB/0.2%.
Any thoughts or comments, Pete?
Paul
Okay- while you're at it-
I would like to see the effect on a cap using a pickup coil, and placing the cap inside the coil. I know caps have an affect on coils if the body is silver-mica or aluminum, as it should in theory, but what about vice-versa?
Can you do this while you're at it?
Thanks,
I'm not sure exactly what you want to do and measure. So would you please elaborate and be as specific as possible (I apologize for seeming dense and no promises). I think you want a cap to be placed inside the air core of a "driven" inductor, then measure the cap to see if its value changes?
Edit: Or, do you want to see if there's any crosstalk voltage picked up by the cap?
Paul
Thanks,
WolfLast edited by Paul K.; 03-04-2013, 04:57 PM.
Great work. I was curious what might happen with the two coils being different sizes (and this is the most likely scenario, IMO.) Sounds to me like it might be an impedance mismatch -- working in our favor in this case -- causing transmission losses from the imbalance. Cool stuff. I really appreciate your taking the time to test all this.
I'm inclined to agree with your results. Below -40dB, you're looking at less LF-to-HF bleed level than the highpass filter itself will allow. Less is always better, but that'll do.
