So I finally ordered my drivers for InDIYana. While I can't talk about them until after the show, I wanted to ask about box damping in general. I don't think this will be a issue with the contest rules as it is a theoretical conversation. However we can use the limit of 12L bookshelf box size in this discussion. I have seen a very good example of a mass loaded box in Wolf's Stance speaker last year. And we all had heard about the importance of bracing. My thoughts for this design are drawn in each of these directions. For mass loading i would like to build a box and then line the inside with non shrinking concrete. Going the other direction is to use interlocking 1/4" bracing at 3-4" spacing. These would be laser cut. Which would be better? Or is this just over kill and a single brace tying the sides together will be fine? What are your thoughts?
Bracing vs mass loading?
Re: Bracing vs mass loading?
Originally posted by duanebro View PostWhat are your thoughts?
Adding the red brace gives the same stiffening effect as doubling the panel thickness. Adding the blue braces gives the same effect as quadrupling the panel thickness. Either is a lot easier than using concrete.
As for polling, this is engineering fact that isn't influenced by opinion.
It would if you mass-load on the exterior, as I did. Damping (notice no 'en' there, no wet boxes apply) is one thing, typically of the absorbant variety. Mass-loading make the panel have a higher potential energy, and harder to resonate due to it being heavier. Bracing makes breaks the panels up into smaller sections between bracing parts, and shifts the resonant frequency into a high range where it won't interfere with the midbass region. All three together would be the trifecta.
Originally posted by duanebro View PostWhile I agree with you Johnny, I would think that it would be very difficult to do both at the same time.Don't listen to me - I have not sold any $150,000 speakers.
Instead of just adding mass, why not be more sophisticated about it and use CLD? David Smith (Snell, PSB, KEF, McIntosh, JBL, etc.) mentioned on DIYA that the cabinets for his big Snell XA Reference speakers used two layers of MDF with car-fi noisekiller spray between them.
As for bracing, in KEF's LS50 "whitepaper" marketing doc they discuss mounting the cross-bracing to the cabinet via some sort of mastic rather than a rigid mounting system. No idea if that's more a marketing point than a substantive one, admittedly.--
"Based on my library and laboratory research, I have concluded, as have others, that the best measures of speaker quality are frequency response and dispersion pattern. I have not found any credible research showing that most of the differences we hear among loudspeakers cannot be explained by examining these two variables." -Alvin Foster, 22 BAS Speaker 2 (May, 1999)
Here is a link to a wiki that you might find interesting though the link to Tolvan seems to be dead http://www.diyaudio.com/oldwiki/inde...abinet+Bracing. Moriyasu did some actual testing and published in AES around a decade ago, if you can find the article. Here is another that also references the article: http://bellsouthpwp.net/l/j/ljfrank/Bracing.html. And finally, another discussion: http://www.hometheatershack.com/foru...materials.html
JayJay
Our greatest glory lies not in never falling, but in rising each time we fall.
Simple crossbracing with appropriate internal fill seems to produce good results in most situations. Shelf braces can yield particularly rigid and well damped larger cabinets and can be easy to implement. Mass loading of panels seems of more limited application and much more expensive if commercial products are employed over large surfaces.
didn't answer the poll as I've only done shelf bracing, but I did a little experiment with 3 pieces of wood about 6"x12" one 3/4 mdf, one 3/4 H.D. plywood, one piece was two 1/2" pieces with a ~3/16 layer of urethane rubber between, the rubber won, so my next project will be that combo with bracing. though I should glue two pieces of 3/4 mdf together to compare.David
Originally posted by skatz View PostWhat about stiffening ribs on the side panels. If placed assymetrically they spread the resonances, and they can be crosstied with bracing too.
