Subwoofer Replacement Question
  • Subwoofer Replacement Question
    Calling all subwoofer design gods...
    I know from what I have read that the most important parameters for replacing a subwoofer are the following:
    fs
    vas
    qts
    xmax
    I have been looking for a cool low cost subwoofer build that would give me some deep thumping bass and would reproduce LFE from movies without sounding like muddy crap like my current sub does. I am also somewhat limited in space. What I have been thinking about building was Paul Carmody’s Pony sub.
    I like the look of the pony sub and I think it would fit nicely into my living room. The thing that is holding me back right now from the build is an expensive driver. If my hypothesis is correct I think I may have found a low cost replacement for the driver being used in the pony sub.
    Below are the parameters for each driver. Do you think they would be interchangeable?
    Dayton Audio RSS210HF-4 8" Reference HF Subwoofer 4 Ohm
    THIELE-SMALL PARAMETERS
    Resonant Frequency (Fs) 28 Hz
    DC Resistance (Re) 3.3 ohms
    Voice Coil Inductance (Le) 0.68 mH
    Mechanical Q (Qms) 3.08
    Electromagnetic Q (Qes) 0.60
    Total Q (Qts) 0.50
    Compliance Equivalent Volume (Vas) 1.14 ft.³
    Mechanical Compliance of Suspension (Cms) 0.48 mm/N
    BL Product (BL) 7.76 Tm
    Diaphragm Mass Inc. Airload (Mms) 66.02g
    Maximum Linear Excursion (Xmax) 9 mm
    Surface Area of Cone (Sd) 219 cm²
    MCM 55-2421
    Power capacity: 120W/240W RMS/peak
    Frequency response: 25Hz ~ 1KHz
    Nominal impedance: 4Ω
    Voice coil diameter: 2"
    Magnet weight: 47oz.
    Sensitivity: 87dB W/M
    Fs: 25.7Hz
    Re: 3.4Ω
    Le: 2.47mH
    Qms: 14.0
    Qes: 0.22
    Qts: 0.22
    Vas: 30.43 liters
    Mms: 59.78g
    Xmax: 8mm (one-way)
    Magnet gap height: 8mm
    BL: 12.99
    Piston diameter: 163mm
    Let me know what ya al' think :D
    Kevin
    Shaken, not stirred...
    Classix II
    OS MTM's
    Digger 8 sub
    Overnight Sensations Center Channel
    Sprite Build
    Wolf's PC Speakers
    Minions III with Voxel Sub
    Re: Subwoofer Replacement Question
    fs
    vas
    qts
    xmax
    That's a tad too simplistic. You need to use Qes and Qms for best results. Qts is derived from Qes and Qms, but the Qes and Qms of two drivers can be quite a bit different while Qts is still pretty close. That said, the hugely different Q figures of the drivers you're comparing makes it very unlikely that they would both work well in the same cab. As for choosing a driver, there's no substitute for modeling the response in the intended box with a modeling program.
    www.billfitzmaurice.com
      Bummer, I was hoping for a low cost alternative.
      Thanks Bill!
      Kevin
      Classix II
      OS MTM's
      Digger 8 sub
      Sprite Build
      Wolf's PC Speakers
        Take the time, spend a day and learn to model a woofer in Unibox or WinISD. Chances are you may find there is no magic cheaper driver that will work as well (or maybe you will). But the knowledge you gain will be priceless.
        Thanks Bill!
        Kevin
          Spend a day,,,, a DAY? For someone like me it's more like 5 days! Ok 10,,,, well maybe even more!
          There may be no magic cheaper driver but,,,, listening to the people hear and building something that sounds really good,,,,, now THAT'S MAGIC! And PRICELESS is exactly the way I'd describe the knowledge I've gained here! Thanks all! Mark
            Kevin,
            I have been doing a lot more modeling in winisd lately as the laptop I use most doesn't have MS Office for Unibox or Jeff's WBCD, I think Unibox and WBCD is more friendly to me (just my opinion) but getting more comfortable using winisd.
            I believe Johnny Richards has written a tutorial on winisd, and Chris Roemer has a post somewhere about a good practice of entering parameters.
            If I can be any help, I will do what I can. Been playing lately with some 8's to go behind my spot on the couch and am continually getting more comfortable with the results.
            I have a thread with some models in it, per Chris R recs.
            The model attached is 2x 8" in a 2cuft vented box with a little boost applied right near tuning.
Name:	TB - 8x2 - Driver_TFM.jpg
            Just get in there, punch in some numbers and see what happens, It is cool to see how different drivers act - and for myself, just barely scratching the surface of difference in parameters = much different results.
            Most if not all of the more experienced guys, can look at parameters and get a good estimate of what a sub will do before even modeling - most impressive.
            THOMAS BROWN aka "STINKY"
            I've got an idea - an idea so smart that my head would explode if I even began to know what I'm talking about. - Peter Griffin
            I DON'T CARE WHAT KIND OF MUSIC YOU LISTEN TO, OR LIKE.
            SHUT UP, PUT DOWN THE WALLS OF PRETENSION FOR 1 SECOND AND JUST LISTEN TO THE SONGS
            - SCOTT IAN
              I've seen the Infinity 1260w 12" sub going for less than $60, and sometime closer to $50 on the net.
              Used in a 14"x14" x 26" long box, with a 4"PVC x 21" long vent, it can take all the power of an unboosted Dayton SA250 amp down into the low 20's, with an F3 of 27Hz, where it looks to be capable of 107dB.
              Chris
                +1 for the Infinity......best bang for the buck right now. As an option, build a 1.5 cu. ft. sealed box before bracing and driver, power it with an amp of your choice, 300 watts. May get one myself to play with.
                Currently resigned to living in balmy Zephyrhills, FL with the snow birds.
                Howard H
                  Thanks everyone for your input. I googled the infinity sub listed above and found a document from infinity. The PDF shows sealed, vented, and band pass cabinets and the volume needed for each including port sizes. I wanted to see what you guys thought.
                  Infinity Link
                  If indeed thier plans would work I would consider getting either a 1.25 cf sealed or a 2.0 cf vented cabinet from DIYsoundgroup.
                  What do you guys think?
                  Kevin
                  Classix II
                  OS MTM's
                  Digger 8 sub
                  Sprite Build
                  Wolf's PC Speakers
                    All of Erich's cabinets are superb. The ideal sealed size box is around 1.3 cu. ft. according to WinISD (for a Q of 0.7). The 1.25 sealed would do, though the driver/amp volume would subtract a little from that. Since the DIY Soundgroup boxes are cubes, you would need to get creative if you want to tune it low (port placement/length). Either way, you would need to contact him directly to get the baffle cut special for the driver, or do it yourself. The simplest build is sealed, no worries about driver overexcursion below cabinet tuning.
                    Howard H
