Hey guys,
I'm in the middle of my first speaker project. I'm using some Dayton Audio ND65-8's:
http://www.parts-express.com/pe/show...number=290-206
And a DTA-2 amplifier:
http://www.parts-express.com/pe/show...number=300-385
According to the specs on the speaker, and inputting the parameters into BassBox 6, I came up with a test enclosure made from 1/2" MDF. All joints are glued and pin-nailed except for the front so I can detach and make modifications inside:
I started everything up and immediately noticed that it didn't have nearly the amount of bass I was expecting. I pulled my Radio Shack SPL meter (C weighting, fast response) and tested the frequency response between 40Hz - 300Hz:
One problem is the noticeable dip between 150-190Hz...any ideas on this one?
The rolloff below 120Hz pretty much mirrors the official spec sheet from Dayton. But according to Bass Box the F3 for this enclosure is right around 59Hz so I expected this thing to hold steady down to that frequency...maybe my expectations were wrong? Could my port be too close to the back wall (it's about 2.5 inches away) and I should be adding a 90 degree elbow in there? Could I have just enough tiny air gaps that the port can't perform it's duty correctly? Am I just expecting way too much from a 2.5" speaker?
Here's what BassBox came up with for the box and port configuration:
Another weird phenomenon was that stuffing the box with Acousta-stuf actually made the bass response much worse...it was noticeable by ear right away and the SPL meter confirmed: 50-60Hz dropped by 4dB. I had to just add a minimal amount at the very back of the box, and that was almost the identical response as having no padding whatsoever. Again, my expectations about the magic properties of Acousta-stuf were incorrect to begin with.
On the bright side, I listed to "No Surprises" by Radiohead and heard details I've never heard before. I hooked up a couple other pairs of speakers to make sure I wasn't crazy and sure enough, they didn't reproduce that detail (you could hear the guitarist's fingers on the strings on the repeating four note intro). I just wish I could get the bass out of this thing that I was (perhaps over-enthusiastically) expecting!
Any help would be greatly appreciated!
Thanks,
Rob
Thanks,
Rob
