My goal for this build is some nice high end towers for my man cave. I am basing part of my design off of Elemental Designs EL8 series speakers. The goal is to have a full 7 speaker setup using all the same drivers.
The drivers that I have chosen to complete this task is the:
Peerless 830869 8" Nomex Cone HDS Woofer
Tang Band 75-1558SE 3" Textile Dome Midrange
Morel CAT 408 1-1/8" Compact Soft Dome Tweeter
For the towers I will have two 8" Peerless, 3" TB Mid, and Morel tweeter.
The drawing is a little different, but I plan on relocating the port to the rear of the box and the mid will be mounted on the backside of the baffle with a 45* chamfer.
So far with this project I have received the drivers and done some frequency response testing and working with PCD to get the hang of things. Here is what I have come up with so far using SPL trace and ZMA files I got with DATS.
The response is nice and flat and I also have the baffle step included in the woofer response file. After playing around with different settings in PCD and using a couple other software, I really tried to keep the crossover simple. If anyone spots a bad thing let me know, I will not be able to test the true FR of the drivers until I build the boxes.
Give a little idea of the box, it will be about 75L with a 4" port tuned to 37 Hz.
If anyone has suggestions/comments they are more then welcome.
