Re: How to turn your AudioSource AMP 100 into a real amp. (Paying it forward)
You could probably accomplish this with a RatShack 25W pencil iron, some tweezers, and one of their vacuum desoldering pumps.
http://www.radioshack.com/product/in...ue=Desoldering
The trick is knowing how to use your tools. Here's a big hint - sometimes you have to add solder to be able to suck it away.:eek:
Personally, I go at it by holding one side of the component with the tweezers and pulling slightly up on it. Then, I touch the solder (on the back side of the board) with the iron. Once the solder melts, the component lead will pop out of the board, leaving the other side attached. Then repeat for the other side of the component. Once the component is out, use the desoldering pump to suck any solder out of the empty hole so that the next component can go back in.
Caps are a bit more challenging since you can't raise up one side of the component. Generally, if your iron has a wide and hot enough tip, you can lay the iron across both leads simultaneously and pull out the cap with tweezers.
