Re: How to turn your AudioSource AMP 100 into a real amp. (Paying it forward)
OK - this helps a lot. This means that the offset is getting worse as the volume goes up, but the DC blocking caps (C104/C204) are doing their job and preventing a more serious issue. So long as the cone goes back to normal, the speakers should be OK. If it ever goes out and stays out, then that's bad.
Basically - once we chase down the offset issue, this cone movement will go away.
That's a bummer. If you can get the crimp part out of the overmold, you can solder the wire to the top of the crimp. Otherwise, soldering to the bottom of the board is OK. The experiment seems to be revealing that the offset is coming from the rear panel board as I expected.
Basically, what I would recommend at this point is to double check all of your work on the rear panel. If you can't find any solder issues, try removing all the parts you changed, clean them up, and replace them. However, I'm willing to bet that the issue is *either* the IC5 op-amp or the relay, with my money being placed on the IC5 op-amp needing replacement.
The measurements should have been checked in whatever manner you were getting the amp to "fail". So, it really doesn't matter. However - in good practice, you would at least use a grounding plug on the inputs (one that shorts the ring to the sleeve). This shouldn't be necessary, though - as there should be a pull-down resistor already there.
Originally posted by Rcstark
View Post
View Post
View Post
