How to turn your AudioSource AMP 100 into a real amp. (Paying it forward)
  • Rcstark
    Re: How to turn your AudioSource AMP 100 into a real amp. (Paying it forward)
    Originally posted by AJ View Post
    For standard 60/40 rosin core, you want to be regulated around 700F at the tip. That's the setting to use with a Weller or Hakko station. I don't know how you were getting your temp, but it's not ridiculously high. As long as you didn't linger too long, I don't think you did any damage.
    Thanks, good to know
  • AJ
    Originally posted by Rcstark View Post
    I think my iron was soldering around 780 F and did do some pins on the ICUs fairly close together timing wise.
  • Psycoacoustics
    HAHA. All that worry for nothing. Thanks for the guidance on it though, I'll have a few beers tonight and enjoy it.
    Have a few for me too! Nice job! Enjoy, Mark
  • Rcstark
    Originally posted by tyger23 View Post
    Sorry for the delayed response on this. I just got back home from a long period of travel, and I checked out my AMP-100. Guess what - it does the exact same thing. Once I get to about 7/8th of the volume level, the cone will move and settle back out, and a hum becomes audible.
    I've never tried to get it that loud, so I've never noticed it before. I wonder now if the stock AMP-100 will do that...
    Anyways, it sounds like we went thru a bunch of extra work that maybe wasn't necessary. I've been enjoying my amp for some time now, so I'm willing to bet that yours is OK too. Run with it!
  • tyger23
  • Rcstark
    Small update for those who are following, sorry if this thread is a bit derailed at this point. I removed the relay, IC5 and the specific resistors and caps. Upon turning on the amp with no source connected there is extremely small cone movement at the very end if the volume pot. When I connect a source to input 2 I get the same cone movement as before removing the componentsonly it is much more subtle. I found it only happens when a source is plugged into the red female jack. Also accompanied by a slight buzz (touching the rca cable can make this stop). Putting the cable on top of the amp also makes it worse.
    Measuring the DC voltage at the speaker output and I can see when I move the pot to the specific area the voltage goes up quickly to -.5V and the cone moves in then the voltage returns to normal. When moving it back from that position the voltage goes to .5V and the cone moves out followed by returning to lower voltage levels (less than 20mV).
    I think I'm going to leave this as is as I don't have the expertise to fix the issue and I don't think it is a problem since the voltage drops to normal levels. Plus I don't think the volume will ever be turned up that loud!
    Thanks tiger23 for your help and I'll have to buy you a beer if you're ever New Jersey area! If you can think of anything else I can check on let me know, otherwise I think I'm just going to enjoy the amp. It still sounds fantastic!
  • Rcstark
    So..... After powering up the amp and letting it warm up for about ten minutes I measured the rca jacks again and get a much lower voltage, around 20mV for input two and more like 85mV for input one. It seems like input two voltage rises over time as it's gone up a bit over the last few minutes.
    C413. -9.1mV, 27.9
    C414 -0.3, 22.0
    C412. -0.2, 84.6
    C411. -0.1, 84.9
    Input two voltage continues to rise slowly as well as the voltage on the positive leg of C413, C414. Only anomaly I see, (and trust me I don't see much about this stuff yet) is the -9.1 on 413. I take it after exiting the caps voltage should be very close to zero.
    Now I'm really guessing here but should the rca voltage mirror the negative leads of those caps? Seems like they're showing what the positive leads are.
  • Rcstark
    This concerns me a little. It almost seems like your DC blocking capacitors aren't doing their jobs. Can you check the DC voltage to ground for both the positive and negative leads of C413 and C414 (I think those are the two caps in the center)? Those are the tall caps directly next to the RCA jacks. You may want to go ahead and measure the C411 and C412 leads as well (the two outer caps), but I don't expect you to find much there (unless I don't have my schematics remembered correctly).
    Sure I'll be able to check later tonight after work.
  • tyger23
    I actually get .4 Volts across the tip and sleeve of input two for both the left and right jacks.
    Input one gives me 32mV and 37mV red and white respectively.
  • Psycoacoustics
    Appreciate the help mark!
    It probably was too high but, live and learn I guess. Hopefully it will all work out with the help of Tyler23! After all he is being super patient with me haha. If not at the very least I learned a few things.
    Agreed! He's the best! Always seems to have time for us common folks! Keep pluggin' away. Mark
  • Rcstark
  • Psycoacoustics
    Okay. Would it be correct to go back and reflow the solder around all the components I replaced? I would rather not take them out as my desoldering skills aren't great and I'm worried about damaging an op amp that way. Also what are the chances I damaged IC5 with too much heat? I think my iron was soldering around 780 F and did do some pins on the ICUs fairly close together timing wise. I'll report back after trying to reflow the solder if that makes sense.
    The way I am checking for bad solder joints is by continuity checking with other components on the same trace, is that correct??
    Thanks.
    I supose if that does not work I could just remove ic5 the relay and other parts associated with the auto switch and do the rework without the switch.
    That temp seems high to me. I have the middle of the line Stahl and when I did this I was at about 475 with the small pointy tip. I only get to 750 when I'm soldering wires with the large chisel tip.
    Just trying to help, Mark
  • Rcstark
    Thank you, Jedi. If I understand that correctly measure from ground to the inside of the female rca input?
    Seems out of whack and I'm only saying that because you seem to have expected no DC voltage there!
    As far as shorts I'm 99% sure there are none, I've checked all traces in the vicinity of others and have inspected it to the best of my ability and couldn't find anything.
  • tyger23
    Thanks.
    You're leaning quickly, padewon. Reflow is a good idea, as is removing the IC5 and relay if you don't want to replace the op-amp. It is possible to damage the op-amp with too much heat, but I can't really say if that's what happened or not.
    Before making any changes, though - you might want to check to see if there's any DC offset on the actual input jack. I can't imagine why there would be, but it's worth a check. Just measure across the sleeve and the tip of IN2.
    Oh - and checking for bad solder joints is good, and the way you're doing it is OK. What you may be missing, though, is inadvertent shorts to other traces.
  • Rcstark
    Thanks.
