Neil Davis and I have started working on this (mostly Neil :D ) based on talk in an earlier thread. My plan as of now is based around the PGA2310, and the goal of using through hole parts for everything to make construction easier for most DIYers. The other goal is keeping it relatively inexpensive. My current thinking is going the modular route. We would have a microcontroller board which is standard, and two different analog boards for the PGA's. One would be for eight balanced channels, the other would be for eight unbalanced channels. You would buy the standard microcontroller board, and whichever version of the analog board you wanted. For people not into active crossovers, we could do a 2ch balanced/unbalanced board later.
Features list:
The power supply would be based on LM317/LM337 regulators, with an LM7805 for the +5V rail. Ideally, two small transformers would be used to keep the +5V separate from the +/-15V, and to limit dissipation in the +5V regulator.
This is all dependent on interest so if you're interested but see something you don't like, speak up. However, do not expect tons of additional features. This has to stay relatively simple to be affordable.
Features list:
- IR Remote Control
- Front Panel Volume Control
- Regulated power supply on the microcontroller board minus the transformer(s)
- Small LCD screen to show volume level
