New waveguide with vifa OC25SC65-04
  • New waveguide with vifa OC25SC65-04
    Today I altered a waveguide that TN Allen made for me a while back. The tweeter is a flangeless vifa. http://www.parts-express.com/pe/show...umber=264-1018
    I had to hold the tweeter in the waveguide by hand. Off axis measurements angles are approximately 30, 45, and 60 degrees. The on axis is the one with the distortion shown. All measurements are with a x-over consisting of one cap, and one coil. The distortion below 2k is actually lower than it appears to be here. This tweeter will probably be crossed at 3k.
    Edit...I don't know why, but now I measure a dip on axis at 7k. The only difference I know of is that now I have a piece of wood holding the tweeter in the guide. It's possible that the location has changed very slightly. Off axis still looks about the same though.
    Re: New waveguide with vifa OC25SC65-04
    Nice, got a pic of the waveguide?
    Kenny
    http://www.diy-ny.com/
      Here's the distortion with a filter that allows the response to go lower. Note that at 1.5k, it's -70 dB.
        Can you make this on TN Allen's new jig?
        Kenny
          Sweet
            It's very simple, but part of the guide is flat. TN Allen and I are working on a new guide that is similar to this one. It has a constant radius of about 6", and could likely be made with his jig. This one was altered. I cut the depth back about half an inch. There's a lot of body filler in it. I hand sanded it. It should be relatively easy to duplicate. I think the Vifa is responsible for most of the performance.
              Here's a picture. It's about 6".
                Looks BIG. Can you use it to cast other waveguides?
                Kenny
                  It was cut out of a thick piece of wood. The back side was cut away with a router, and a new piece of wood inserted. Then I added body filler, and sanded it. This would be easy to make.
                    Post a pic with the tweeter in the opening. I'm curious about where the dome sits relative to the opening.
                      I posted this too quickly. I still think the vifa will be a good candidate for a waveguide, but this guide is not as good on axis as I originally measured. I really don't know why the measurements changed.
