3way Kappalite 3012LF + Satori 4ohm + RAAL 70-10D
  • 3way Kappalite 3012LF + Satori 4ohm + RAAL 70-10D
Name:	kappalite 83.6L 11cm diam x 15cm length.jpg
Name:	kappalite 83.6L excursion.gif
Name:	kappalite 83.6L port velocity.gif
Name:	satori sealed 15.4L.jpg
    Re: 3way Kappalite 3012LF + Satori 4ohm + RAAL 70-10D
    omnimic measurements for 3012LF 1/48th smoothing @ 1.2m on axis
      omnimic measurement on Satori @1.2m on axis 1/48th smoothing
        omnimic measurement on RAAL @1.2m on axis 1/48th smoothing
        the thing is, i always get dropping response in RAAL, is this omnimic problem?
          z-offset are -0.022 for midrange and -0.09 for 3012LF
          vertical offset are -0.145 for midrange and -0.505 for 3012LF
          im using PCD to create the crossover, this is my first time, so here are my questions :D
          1. Is it correct to use on axis measurement for creating transfer function? assuming if we input the vertical and z-offset the pcd will simulated it?
          2. i got horrible peaks and dips across the response that i dont know which ones i should address it first. the standout hump would be the baffle step around 600-1khz.
          3. im trying to use first order electrical to achieve LR2, this is possible, but again i dont know how to address the dips and peaks.
          any help will be greatly appreciated,
          cheers
          henry
            Roman measured a similar high end droop in the RAAL he measured. I believe he took his measurements in SoundEasy.
              If you want to verify your tweeter, you can send it to me with the return shipping label and I'll measure it on a wide baffle, calibrated mic, Sound Easy. I also have Omni Mic and can check it with mine but usually Omni and SE give very close results with the difference in presentation.
              For shi.ts and giggles I have Raven R1 on hands and permission to publish measurements by the owner. That should be interesting too.
              Henry, can you post graphic files of your responses? I don't have any audio software on my home puter.
              http://www.diy-ny.com/
                The 70-10D measures very flat. Which test track number did you use?
                  hi rick,
                  i used track 2, mono sine sweep. i think when i measured both speakers in pseudo noise, the highs improve, but i didnt save the graph.
                  hi r-carpenter,
                  here's the snapshot of raal
Name:	raal 70-10d 80cm and 120cm.jpg
                  cheers,
                  henry
                    some snapshot on kappalite
Name:	kappalite 120cm on axis.jpg
                    on satori
Name:	satori 120cm on axis.jpg
                      hi rick,
                      hi r-carpenter,
                      [ATTACH=CONFIG]38145[/ATTACH]
                      cheers,
                      henry
                      Can you post one of the RAAL from a closer distance and see if the top octave improves?
                        [ATTACH=CONFIG]38146[/ATTACH]
                        on satori
                        [ATTACH=CONFIG]38147[/ATTACH]
                        how was this gated and how was the mic position?
                          hi jeff,
                          thanks for chiming in. here's the 20cm RAAL graph, it still looks similar
Name:	raal 20cm with foam.jpg
                          RAAL 20cm, NO FOAM
Name:	raal 20cm NO  foam.jpg
                            hi r-carpenter,
                            both 3012LF and Satori is on 1.2m distance and 15msec gated.
                            henry
                              hi r-carpenter,
                              henry
                              15 mSec is a very long gate time. When you do the sweep look at the impulse and see at what point ripples begin to develop in the impulse response after the initial impulse has settled back to a flat line. These ripples are reflections. Then set you gate time inside the time of the first reflection. This will give you a much cleaner response curve.
