3way Kappalite 3012LF + Satori 4ohm + RAAL 70-10D
  • #31
    Re: 3way Kappalite 3012LF + Satori 4ohm + RAAL 70-10D
    Originally posted by Pete Schumacher ® View Post
    The phase is fine, so is the impedance. The phase wrap is a result of the crossover and acoustic slopes.
    If you don't mind, flip the mid polarity and post the result to see how deep the reverse nulls are (phase tracking).
    Pete, I am surprised you didn't mention that there is no crossover roll-off below 1khz for the ribbon tweeter.
    Henry, what is your highpass circuit for the tweeter?
    • #32
      hi jeff,
      its 3.9uf, LR2 @3khz.
      pete,
      here is the reversed midrange. actually something bothering me also, i need to reverse both midrange and tweeter to get flat response.
Name:	satralkap null no phase.jpg
Name:	satralkap null for phase tracking.jpg
      cheers
      henry
      • #33
        i think its prob not deep enough. :(
        • #34
          allright,
          i added 1mH for the RAAL, prob better for safety and preserving power handling.
          here's the responses, transfer function and impedance
Name:	satralkap mk2 flat.jpg
ID:	1150579Click image for larger version
Name:	satralkap mk2 impedance.gif
ID:	1150580Click image for larger version
Name:	satralkap mk2 transfer function.gif
ID:	1150581Click image for larger version
          cheers
          henry
          • #35
            I did notice that, but I assumed that he was using a single cap. The actual transfer function at the ribbon itself would still be a 2nd order electrical transfer function due to the transformer circuit.
            • #36
              Originally posted by henry218 View Post
              hi jeff,
              pete,
              [ATTACH=CONFIG]38215[/ATTACH]
              [ATTACH=CONFIG]38216[/ATTACH]
              cheers
              henry
              LR4 keeps drivers in phase. LR2 requires one to be reversed. So with a woofer/mid LR2, you need to reverse the phase of the mid. And with LR4 to the tweeter, tweeter need to be in phase with the mid. That means both mid and tweeter will be out of phase with the woofer. Does your baffle allow the tweeter and mid acoustic centers to be aligned?
              Adding the inductor can't hurt, but there's a primary inductance built into the tweeter. Your first XO was probably just fine, but if you're getting better phase tracking with the extra inductor, why not?
              • #37
                thanks pete, i know you got plenty experiences with raal. your comment just made me confident that this xo will actually works
                • #38
                  now the fun part starts. Keep the crossover external. Massage the tails of the drivers response, listen to different variants and slopes. Mini DSP is actually very good for it. You can change the slopes digitally and listen to the effects and after you are satisfied with the outcome, execute it with passive components.
                  http://www.diy-ny.com/
                  • #39
                    I think I figured out what he did - he measured his RAAL response and impedance with the cap in place. PCD sees that as the driver impedance which then cancels the predicted roll-off although it's actually there in reality.
                    What I do is measure my ribbons with a cap in place, then I manually extend the response of the tweeter wherever it begins to roll-off an extract the phase. I also measure impedanc without the cap. When I import these files I can then model the crossover accurately for the parts I am using.
                    • #40
                      hi jeff,
                      you are correct
                      cheers
                      henry
                      • #41
                        We actually measure the ribbons with no crossover in place at all. We just limit the signal size to no more than 2.83V and start the sweep at around 300Hz. We've never damaged a RAAL using that method to measure it's response.
                        • #42
                          I have done that too, and that's how I measure other tweeters, but about ten years ago I cooked an Aurum Cantus ribbon (only driver I ever ruined designing speakers) and since then I use a cap on ribbons. Part of my reason is also due to the near short circuit they present at low frequencies. It's just simple for me to take measurements with a larger cap and then extend the response manually.
                          • #43
                            hi pete,
                            thanks for that, just checked the omnimic's track listing, it does have sine sweep with bass remove
                            cheers
                            henry
                            • #44
                              RAAL's impedance is near a dead short at low frequencies too, I would also recommend using a cap. http://www.raalribbon.com/images/products/70-10-m.htm
                              • #45
                                impedance chart on the 3way. i think the PCD is accurate 100%, what a great tool it is. Jeff, again you have made such an excellent tools for regular guy such as me to create a good speakers, cheers
                                btw the PCD screenshot is not the simulated impedance, it just shows better for the phase angle.
Name:	3WAY SATRALKAP DATS.jpg
ID:	1150676Click image for larger version
Name:	3way satralkap total impedance.gif
