How can you make regular speaker wire to be balanced like the XLR wires. I will make wires same length from left to right. TIA Eric
Balanced speaker wires
Re: Balanced speaker wires
Originally posted by Mad Bomber View PostHow can you make regular speaker wire to be balanced like the XLR wires. I will make wires same length from left to right. TIA Eric
There is no need to have speaker cables the same length either.
http://www.diy-ny.com/
Originally posted by Mad Bomber View PostSo what is the best speaker wire for medium to high end system? System will bi- amp speakers. I've got 3 sets of B&W's 600's series with 2 subs in a 18X24 room
There is nothing to be gained in spending one penny more than you have to.
BTW, there is also nothing to be gained by either bi-wiring or so-called 'passive' bi-amping. If you're not using an electronic crossover to separately amplify the high and low frequencies and the passive crossovers in the speakers are not bypassed you're not bi-amping.
bill I would like to agree with your last statement but can't. I use a separate amp for lows and mid/highs. passive crossovers in full. there is a huge audible difference than using a single amp. I tested and had another set of ears that confirmed. as far as wiring I concur but 2 amps made a world of difference to me.
I agree with chuck. I use a pair of Jeff Rowland mono amps on top, and Spectral 250 on the bottom and there is a large difference in sound over just using one amp in the system. not that I do not like the Spectral to drive the speakers, I just prefer the Rowlands warmer top end on most music. if I am looking for a little more detail, less warmth, I take the Rowlands out of the loop. I agree that using one amp with 2 channels and bi wiring will not get you much. I also will have any one that does not think that there is a difference in the sound of good amps to come over and listen. amps have a sound.craigk
Originally posted by billfitzmaurice View PostPure copper, of adequate gauge. Use this to determine gauge requirements:
BTW, there is also nothing to be gained by either bi-wiring or so-called 'passive' bi-amping. If you're not using an electronic crossover to separately amplify the high and low frequencies and the passive crossovers in the speakers are not bypassed you're not bi-amping.John k.... Music and Design NaO dsp Dipole Loudspeakers.
Originally posted by isaeagle4031 View Postbill I would like to agree with your last statement but can't. I use a separate amp for lows and mid/highs. passive crossovers in full. there is a huge audible difference than using a single amp. I tested and had another set of ears that confirmed. as far as wiring I concur but 2 amps made a world of difference to me.
Originally posted by isaeagle4031 View Postbill I would like to agree with your last statement but can't. I use a separate amp for lows and mid/highs. passive crossovers in full. there is a huge audible difference than using a single amp. I tested and had another set of ears that confirmed. as far as wiring I concur but 2 amps made a world of difference to me.-Mike
Originally posted by Alien_Shore View PostWould that imply that the single amp is underpowered?Dave
If you can read this, thank a teacher.
If you are reading it in English thank a Veteran.
If you are planning to bi-amp, then I suggest Canare 4S11 cable as a possible cable. The 4S11 cable consists of 4 separate 14 AWG conductors in one envelope so you can use it for a bi-amp situation.
Normally, I use 4S11 for stereo and connect it in star quad configuration which ties the two red conductors and two white conductors together at each end so that an 11 AWG cable is attained with noise rejecting properties.
I would add Speakon connectors to your speakers so that connections are solid and more trouble free via Speakon terminations. The bi-amp pair of 4 total conductors can be conducted down a single cable and kept separate if you use Canare 4S11.
