If you have an immediate customer service issue, please visit us at Parts Express
Don't forget the Sprite as well, as that is another rendition.
"Wolf, you shall now be known as "King of the Zip ties." -Pete00t "Wolf and speakers equivalent to Picasso and 'Blue'" -dantheman "He is a true ambassador for this forum and speaker DIY in general." -Ed Froste "We're all in this together, so keep your stick on the ice!" - Red Green aka Steve Smith
I am expecting a pair of NS3s, so I am going to build at least yours and Chriss designs and have them measured, and would love to build the Sprite (which would be a permanent and dedicated use of NS3s) in the near future.
Finished the Pico Neos today. Just hooked them up and i am thoroughly impressed. Great, and i mean, for two 3" full range drivers, GREAT bass. I heard the deep thump from the other room. These things sound surprisingly awesome.
Now to order a couple 500uf caps and build Wolfs PC.
I did these back in 2004, and was not using FR plots then. However, you could take Zaph's plot for the NS3, and use a shelving filter to flatten out the midbass, and likely be quite close. That's really all the design is.
If i used the pc's as left, center, and right in a small room (11x14) would one w6-1139 be enough or should i go with two; as subwoofer duty.
While one is impressive for what it does, I think 2 would be better for a room that size.
I have both the pico neos and Wolf's PC. I can measure them and post in a couple of days.
do you need the port measurement to be included also? or just a nearfield from about 6 inch on the driver axis at same volume do? I will also do a far field (30 - 36") measurement.
