Has anyone used the anarchy tapped horns as bass bins? I am wondering how a pair would sound with O.S mtm's on top powered with a single plate amp for the lfe.
Anarchy tapered horn as bass bins?
Re: Anarchy tapered horn as bass bins?
Yes, I do at work with a pair of little monitors. A/V receiver with a sub out and a Kenwood stereo power amp. Sounds fine, very narrow. In the background of this pic. There are two, one for each side. I would use a stereo power amp for the two subs, not a single plate amp. Or two plate amps. There is no room to mount a plate amp in the horn. If you have a sub out, you can use any amp.
Originally posted by jonlem View PostHas anyone used the anarchy tapered horns as bass bins? I am wondering how a pair would sound with O.S mtm's on top powered with a single plate amp for the lfe.
Let us know how it goes...
Kevin
Originally posted by jonlem View PostHas anyone used the anarchy tapped horns as bass bins? I am wondering how a pair would sound with O.S mtm's on top powered with a single plate amp for the lfe.--
"Based on my library and laboratory research, I have concluded, as have others, that the best measures of speaker quality are frequency response and dispersion pattern. I have not found any credible research showing that most of the differences we hear among loudspeakers cannot be explained by examining these two variables." -Alvin Foster, 22 BAS Speaker 2 (May, 1999)
I am thinking about using a 300 watt plate amp with 2, 8ohm Anarchy's in parallel from the LFE sub output and crossing 80-120 hz. So these would be my subwoofers. I want to get away from my single big awkward subwoofer. The wife ok'd tower speakers too, so this idea popped in my head.
Pallas, are you thinking there would be a gap between the anarchy top end and mtm low end? I will play around with win isd pro.
Originally posted by jonlem View PostPallas, are you thinking there would be a gap between the anarchy top end and mtm low end? I will play around with win isd pro.
Closed with EQ/vented and maybe 4th order bandpass are just better bets. Lose some efficiency, gain needed bandwidth.--
