A fine gentleman from Finland ordered a set of these and had them sent to me for some waveguide testing after mentioning them from Jeff B's thread.
http://www.madisoundspeakerstore.com...-dome-tweeter/
They have a small surround which made it nice for me to get in close to the dome which really helps out on the top end.
This is in my 165mm x 115mm guide using a 1" throat. It is 1 3/8" deep.
This is with the face plate removed. You can see how small the surround is. I think this is a great advantage when fitting the guide over the surround.
They are advertised with a 94 db sensitivity but I think they are closer to 92 dbs from some comparisons I made against a few other tweeters I know well. Other then that they do really well in the waveguides I've tested so far. Distortion test look like they would be good down to about 1.6 kHz.
10" x 14" Flat Baffle 0-90 degrees
Distortion on the flat baffle.
This is the 165mm x 115mm Elliptical guide 0-90 degrees horizontal axis
Same 165mm x 115mm guide EQ'd flat 0-90 degrees Horizontal
This is Flat baffle (red) vs 165mm x 115mm guide (black) on axis
This is my 8" round guide with a 1" throat. It is 2" deep.
I'm going to test these in a larger Elliptical guide (8x5) and see how they do. I'm thinking about trying these out with the B&C 8NDL51 8" in a sealed two way with the 8" x 5" or 6.5" x 4.5" Elliptical guides.
http://www.parts-express.com/pe/show...number=294-649
Not sure on the woofer though yet.
Dave
Dave
