Well I picked up a Markaudio Alpair 6P Gen 2 (6.2 or whatever :D) for testing, thinking I'll use that in a 3-way with shallow slope crossovers. Right now I'm envisioning an OX20 for the top end, and then some nice pair of 8" or a 10" for the bottom. Here is the first measurement. I did no break in, besides listen to some music. Its on a test baffle (flush and rears routed out for breathing room) 12" wide and 4.25" from the top, like so:
What you can't see behind that is a poorly (but effectively) mated .25 cubic foot PE box providing what could pass as a rear enclosure. I took these measurements with my ECM8000 at 6.5" from the cone (somewhat nearfield) on 0, 30, and 60 degrees. The voltage was calibrated by meter to 2.8V. The off-axis plots are scaled at -5 and -10 db for visibility.
Well alright, so there is an impressive dip from 1000 to 2000 hz with a deep base, -5 db at its worst. Also, some kind of 1200hz 2 order harmonic distortion hiccup. Both of these issues begin to fade when you move off-axis however. So I wonder what the cause is, perhaps cone geometry?
Its interesting that I could not detect the dip or 2nd order peak in my listening, but I didn't do anything extended. I just crossed it over at 150 hz to my subwoofer and gave it a quick listen on acoustic stuff I know well. It sounded nice and balanced, with too much top end sizzle (I could hear the peak above 10k).
More tests to come.
More tests to come.
