Home/Pro 8" 2-way: RS28A and B&C 8BG51
Re: Home/Pro 8" 2-way: RS28A and B&C 8BG51
I start with the volume at -45, pretty loud in the seated position. Gotta be over 90dB, and I'm 3m away from each monitor. Well before the end of the song, the volume setting had moved up over 10dB. And I want it even louder. Basically, here's me during that song.
Wow, these pro woofers could easily get addictive!!!
The sound was HUGE, clean, defined. I couldn't believe how the vocalist stayed front and center, in between the speakers, not in front, not behind. Just right THERE. Didn't matter how loud it played, the sound stage was massive. Chest pounding. Exhilarating. Goosebumps!
Well done,
chuck
Pete,
How much do you think the fact that this is a bookshelf/monitor style box play into the imaging of the speaker. These type boxes have always bested floorstanders in this department, IMO.
Pete,
Getting more and more interested in this project as it continues to unfold. I am curious about pics and polars, not that either one are super critical but I am curious about how you have decided to finish the baffle and how everything looks in that PE cabinet and with the waveguide integrated into the baffle. Also, I am very curious about the waveguide directivity at crossover point and how that lines up with the woofer. I am not a strict follower of Geddes on this stuff but I do take his work and contributions to DIY very seriously so I am always looking to see how his priorities line up with listening experience, and of course, nothing but respect to you, Pellegrene, Bagby and others... I like taking a little bit from everyone and see how it might come together with my own bias/preference.
I am glad to hear that the RS28A is such a strong unit, I have always been a bit hesitant to give this one a try given the other options that get raves around here, such as Transducer Labs and CSS, at least when it comes to waveguide use. Still curious about Dave's experience with the Audax tweeter and then how all of these domes would stack up against the AC aero striction in a waveguide and the TPL-150H, at some point I might start on thread on that and hope I can get a bunch of folks to chime in. Also looking at options for 8-10 inch midwoofers as I think this diameter size is the ideal match for dome oriented waveguides 7-9 inches running down to 1-1.6 kHz. Volt and Audax are high on my list, along some more pro sound stuff like the B&C you chose here.
Anyways, the above musings are really geared around a future high end project, and what is more important is what you have created here, as it looks like you have possibly hit the absolute sweet spot in performance/value for many folks. My home studio still needs a decent monitor (more midfield than near field I suppose) and your project is still at the top of my list. Keep the info flowing as you can, much appreciated.
Regards,
Greg JensenLast edited by Greggo; 12-03-2013, 11:24 AM.
In all seriousness, Nice work Pete. I like to see a concept work. It is a very godo example if when to WG, it is exectuted very well, has a specific purpose and fill that purpose with ease.
Let's not forget it IS NOT a cheap, low skill, or budget build and you have some serious metal in that crossover, so the ROI needed to be exceptional. And from what I can see it is. I would love to get these on my 500WPC Carver Ref. Signature and open em' up
Oh, and thanks for the new Pony GIF!!!!!! :D.
...This will be an 8 Ohm system, and I'm guessing at around 87dB overall sensitivity after baffle step, with F3 about 47Hz, and should be able to produce over 110dB from 50Hz on up...
Just thinking out loud mostly.Thanks,
Aaron
Regards,
Greg Jensen
Hmmmmm . . .
As for 10" woofers that would work with this tweeter, I'd LOVE to try the Acoustic Elegance TD10S. I'm unsure of their smoothness of response to 1KHz, but from the data I've seen on their 12" versions, a 10" should work very well. That woofer would allow you to create a very powerful monitor/small floor stander.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Originally posted by aarond View PostI realize it wasn't ever part of your plan but did you consider going w/ a sealed enclosure? I can do the modeling but I was wondering if you modeled the same size box (sealed) w/ a more gradual 12dB roll off, for use specifically with a sub.
Just thinking out loud mostly.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Originally posted by mzisserson View PostIn all seriousness, Nice work Pete. I like to see a concept work. It is a very godo example if when to WG, it is exectuted very well, has a specific purpose and fill that purpose with ease.
Knowing that information, I can finally calibrate the plot below to actual SPL levels.
The top trace is at just over 100dB. Distortion is flirting with 1%. The mess around 350Hz is related to floor bounce and some low level noise in the sound card. That would make the top trace between 20W and 40W.
So, I sat down in the listening spot and held up the meter while I played back that Alter Bridge cut, at the same volume setting. With both speakers playing, levels hovered at just over 100dB at the seated position, so I gave it another couple dB on the volume control allowing an occasional peak of 103dB, and one peak at 105dB. I figure that's about it for the 120W amp with music. Any more power and the onset of clipping might begin. All I know is, my guesses about how loud it was made me feel pretty good when the meter told me what they actually were.
There is no hint of compression in the above plots. I could probably crank the volume even further, another 5dB before the amp limit is reached. I hesitate because it is already so dang loud. Distortion appears to be rising with power in a pretty linear fashion. Another 5dB of distortion is probably becoming audible if your hearing isn't already overwhelmed by the sheer volume. But the lack of compression is what I really like to see.
They'll be dismantled now to get the paint job on the baffle done. The crossover goes into the cabinet. Once the paint job is complete, pictures.
Piano White baffle and Piano Black cabinet? Or should it be another black baffle to hide the drivers?
When they're finally assembled, I'll get a series of off axis measurements to get an idea of the polar response.R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
Black is so dated, you may want to try Kona, or Obsidian
Dave Pellegrene has put the AST2560 into a custom guide and achieved excellent results. That approach is certainly an option for a two-way like this. Even more expensive though, but a step up in terms of high end resolution and dynamics. Maybe I can talk Dave into making me a baffle set up for the AST2560 that allows me to mount it to the PE .75cf TM cabinet. Not sure if the 8BG51 can be coaxed into a smooth XO at 2KHz.
Hmmmmm . . .
I do have the octagon pattern cut out for the 8" B&C drivers so a couple baffles would be pretty simple to make up.
Let me know if you want to pursue it. Rear mounting may be a good option so a universal baffle could be made to swap out woofers. The pro woofers I've been looking at all seem to fit with a 7-1/4" cut out for rear mounting.
Dave
Pete,
How "sufficient" do you think the bass will be in a small room, about 12 x 14. The speakers will go on the 12' wall and are generally pulled out about a meter from back wall and have about 1.5meters between them. Listening position is 1 meter, but is adjustable, of course. Ceiling is vaulted behind them, but is still 8'.
And for John H, when they're finished, you could stop by Ryan's again and hear them in the nice listening room.
Dave, not sure when, but I may take you up on the offer!R = h/(2*pi*m*c) and don't you forget it! || Periodic Table as redrawn by Marshall Freerks and Ignatius Schumacher || King Crimson Radio
