Another Sprite Build
  • Another Sprite Build
    This has been a long journey but it is finally done. There were some bumps in the road along the way but this will chronicle my Sprite Journey.
    First I need to give Takitaj aka Tom Jones for making such a nice flat pack. It was something that went together quite easily and fit together perfect.
Name:	All parts.jpg
ID:	1187022Click image for larger version
Name:	Front view - no baffle.jpg
    My problems did stem from the cabinet but my own dumb mistakes...
    I had bought some really nice looking Chestnut Burl veneer and I had veneered it up and it looked fairley nice. But when it came to sanding it down I made a bad mistake. I went right through it.
ID:	1187024Click image for larger version
ID:	1187025Click image for larger version
    Shaken, not stirred...
    Classix II
    OS MTM's
    Digger 8 sub
    Overnight Sensations Center Channel
    Sprite Build
    Wolf's PC Speakers
    Minions III with Voxel Sub
    Re: Another Sprite Build
    Since I was a little low on money I decided to use some left over Bubinga veneer. I also found a good deal on some Wenge veneer and decided to do a two tone build. Now I have never done anything like that before. I read what others had done and did some reading on verious websites like joewoodworker.com and came up with a plan of attack.
    I was able to get the veneer on and it came out what I consider OK. I took a trip to my local woodcraft store and the store owner showed me how to fix the cracks that developed in the veneer using sanding shellac. I think I got most of the problems solved and I will let ya al' judge for yourself if you think it turned out ok.
ID:	1153943Click image for larger version
ID:	1153944Click image for larger version
ID:	1153945Click image for larger version
    Classix II
    OS MTM's
    Digger 8 sub
    Sprite Build
    Wolf's PC Speakers
      Looks awesome Kevin!
        That's one classy boom box!
        Isn't it about time we started answering rhetorical questions?
        Twitter: @undefinition1
          Looks great! I am wondering now if I should jump on the Sprite bandwagon.
          “I cried because I had no shoes until I met a man who had no feet”
          If we all did the things we are capable of doing, we would literally ASTOUND ourselves - Thomas A. Edison
          Some people collect stamps, Imelda Marcos collected shoes. I collect speakers.:D
            Looks great man. I love Bubinga. Looks like the veneer on the roundovers came out really good, was it contact cement?
            It's heartbreaking to see sand-through like that. I've done it a number of times myself. After several helpful comments from others, I learned not to use my random orbital unless absolutely necessary for cleanup. And even then, apply no pressure and go very slowly. 99% of my veneer sanding is by hand these days. No belt sander either
            I stopped using paper-backed veneer altogether because you *barely* have any room to sand that at all when it comes time for cleanup for finishing. I'm a messy worker and always end up with glue drips and random bits of sawdust stuck to the cabinet... I need to be able to sand, so it's raw veneer for me.
              Thanks everyone for your comments and complements. The sprite sounds great. I hooked up a lapai 2020 amp to it and played songs threw my phone and we were rocking my living room/kitchen area pretty good. I too am blown away by the bass output of that little guy. In fact I used the EQ built into my phone to trim some of the bass because of the high output.
              I am letting my brother-in-law use it like PC speakers right now and he thinks it is the shiznick. I would think that a pair of the separate sprites or pico neos with that 2.1 lepai amp and a voxel sub would be pretty much make the ultimate PC speaker setup.
              I am sure the sprite will serve us well for many years.
              Thank you Paul for designing another knockout speaker!
              Kevin
              Classix II
              OS MTM's
              Digger 8 sub
              Sprite Build
              Wolf's PC Speakers
                This is great news to me!!!
                I am deep into constructing EXACTLY what you've described. A pair of Sprite seperates and a Voxel sub. Actually......3 pair of Sprites, 2 pair of the Wolfs PC, and 5 Voxel subs. My build thread here -
                Your veneer looks very nice. Id love to get my hands on something like that for my next project!
                Well done!!!:D
                Thanks,
                Jeff
                Projects:
                "Overnight Sensations" Build Thread
                Wolf's "PC", plus Paul Carmody's - "Sprites", and "Voxel" subwoofer 2.1 micro systems - Build Thread
                  Well done!!!:D
                  If your interested in some very nice bubinga click on this link: http://www.certainlywood.com/woodmenulist.cfm?c=63
                  They are the same place that supplies Taylor speakers and are known to carry quality veneers. The stuff I used came from veneer supplies.com and it worked out nice.
                  Kevin
                  Classix II
                  OS MTM's
                  Digger 8 sub
                  Sprite Build
                  Wolf's PC Speakers
                    How are you inputting the music to the Sprite? I don't see input connectors..........Bluetooth?
                      Just a 3.00 cable from PE. Nothing fancy.
                      Kevin
                      Classix II
                      OS MTM's
                      Digger 8 sub
                      Sprite Build
                      Wolf's PC Speakers
                      • #12
                        Ya I was using raw veneer. It was just very thin. The bubinga was much thicker. But live and learn I guess. I was another technique for fixing cracks in veneer from the owner of our local woodcraft store using shellac and sanding particles. It worked lretty well. I think if I have more practice I could get it almost perfect.
                        Kevin
                        Classix II
                        OS MTM's
                        Digger 8 sub
                        Sprite Build
                        Wolf's PC Speakers
                        • #13
                          I don't think I've heard of that one. Maybe i'll search around for videos and give it a shot. I'm a big shellac fan
                          I read recently about filling cracks or small gaps with colored wax pencils that match the color of the final finished surface. Seems *too* easy so i'm a little skeptical. I haven't tried to track down the pencils yet.
                          • #14
                            Duh, I see now. Your version of the Sprite is a speaker cab only............amp separate. Looks great.
                            • #15
                              Thanks, It took a long time but the final result was pretty good. Not perfect by any means but nice. Most of the veneer cracks cant be seen unless you really stare at it. But over all with such great booming sound it will serve us well for a long time.
                              Kevin
                              Classix II
                              OS MTM's
                              Digger 8 sub
                              Sprite Build
                              Wolf's PC Speakers
