Re: Combining Inductors
The whole reason for that PDF is to show the amount of mutual coupling between two inductors and what NOT to do with two inductors in two different circuits. Hence, you should not place two inductors from 2 different circuits as shown in #8.
If you place two inductors in series electrically (but mechanically isolated), they will add their inductance. If you place them in series electrically and put them together such as #8, then you also receive mutual coupling with their fields, so you attain more than A+B inductance. Because of the bobbin, you will have a small gap in the "middle" of your inductor which will cause some loss in the mutual coupling. If you had a single wind with 2x the wire (and the optimal physical size), you'd end up with a higher inductance than the two separates wired together and coupled together. You'd typically use less copper with a single inductor than trying to gang multiples together. So, no free lunch. Coupling together is just convenient if you already have some smaller inductors and need a larger one.
Originally posted by jeff_free69
View Post
