I want to build a line source array using the 3-1/2" HiWave BMR drivers, HIBM65C20-8. I have two questions. First, to obtain optimal constructive interference across the frequency spectrum in the most desired-to-be-affected frequencies, how many drivers should I use per channel? (And how far apart should they be spaced? And what IS the most desired range to have radiate as line source? I'm aware it may be impossible to achieve line source across the entire spectrum with a ""one-way"" or "full range" driver. I know the ratio between width and height affects which frequencies radiate as line source vs point source, but I lack the application know-how. I hail mostly from the pro field, does it not matter as much in home audio? I've never seen anyone concerned about doing the math in home audio applications. They just stack a bunch of drivers (or worse, a few.) and call it a "line array.")
Second, I would like to discreetly amplify each driver-- unless there will be around "hundreds" of them. I know it will be costly, but if I can manage a reasonable amount of drivers (see above question) I would like to try. Should I use a pre-amp before splitting the signal running to each amp, or will simply splitting the line have minimal effects on signal quality? Does splitting the signal divide the line impedance? I know single ended home audio amps are considered impedance balanced. Not sure if splitting effects this "balance."
Thanks everyone! This is my first post here. I hope to stick around.
