Bear with me. Very new to this and working through some ideas in my head as I work on my 1st DIY set. I have a couple quick questions related to port sizing.
1. Are most of the manufacturers port recommendations fairly accurate as it realtes to their box size recommendations? For example, a Hi-Vi L64R driver recommends a .50 cubic ft enclosure, with a 1.5" x 4.25" port. So if I build that size box would I be fairly safe to assume that it is what it is and not deviate from the port recommendations.
2. If I go with a an MTM and put 2 drivers of the example above in a 1.0 cubic ft enclosure would I use 2 ports or could I use the calculation where the port length remains the same and I multiply the width by 1.41. Ending up with an estimated 2.82" x 4.25" port. Don't remember where I saw that calculation. Somewhere on the forums someone gave a calculation for how you would double the volume of a port. They mentioned keeping the length the same and multiplying the width by 1.41. Would it be better to use two ports or increase the single port?
