New shallow woofer design...
http://techtalk.parts-express.com/blog.php?u=4102Tags: None
Re: New shallow woofer design...
Looks interesting!"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.diy-ny.com/
I've been on this board for, I dunno, like 7 years now, and every once in a while, someone comes along and says, "Why don't they just make a woofer with the voice coil going all the way around, just a dome and a surround." And here, finally, someone did it.Isn't it about time we started answering rhetorical questions?
Twitter: @undefinition1
Very interesting. And since they state "linear excursion", I'm assuming this number has been klippel verified.
Says they're offering it in a loaded enclosure. Hopefully they'll offer the raw driver
The configuration of this driver looks like a Bang & Olufsen patent I saw recently, where a rear surround is mounted between the inner edge of a ring motor structure and the back of a dome diaphragm with a cone-shaped protrusion. However, I doubt B&O will be interested in what this guy is doing unless he attains a large market presence.
You can do lots of things with NdFeB magnets, and moving a very large voice coil is one of them, but this looks like a very expensive design to manufacture. We also saw this exhibit at CES, and the driver was not cheap.Best Regards,
Rory Buszka
Product Manager, Dayton Audio
The best way to predict the future is to create it.
Originally posted by winslow View PostI think I just saw some patent information in the newest issue of Voice Coil on this sub...just flipped through and didn't have a chance to read it since the wife cleaned up, and now I can't find the issue.
I don't know much about voice coil construction, so I may demonstrate my ignorance with this question, but wouldn't that much of a voice coil tend to increase impedance quite a bit? There has to be a large amount of wire in that coil even if it's just one layer. I figure around 30" for just one wrap of wire...
Unless they had, maybe two or four separate coils wired in series/parallel etc. to control impedance?
Again, probably just showing how much I don't know.
Super-cool idea, though. With huge magnets and depth with most heavy-hitting subs, this design seems to reduce cabinet volume considerably.
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Originally posted by tomzarbo View PostI don't know much about voice coil construction, so I may demonstrate my ignorance with this question, but wouldn't that much of a voice coil tend to increase impedance quite a bit? There has to be a large amount of wire in that coil even if it's just one layer. I figure around 30" for just one wrap of wire...
TomZ
in the car audio world, shallow subs are not new. in fact, SI has a new version of theirs coming out soon. 3.4" depth, and somewhere in the neighborhood of 15mm linear excursion, IIRC.
JL Audio also has a few varieties but the 13tw5v2 is 2.625" deep and klippel verified at about 11mm. Alpine, Kenwood, Pioneer, Earthquake, etc, etc, all have shallow subs.
That said, this one is about 1/2" shallower than any of the others I know of and if the linear throw value is legit, that's pretty hefty.
I like shallow subs, but most have an Fs that's pretty high. As ErinH mentioned, shallows are common in the car audio world, but I've yet found one that I could use with an alignment to provide more low end extension without EQing the hell out of it in a decent/small-ish box.
Hopefully this new one will be the first to be capable of that. But then I probably couldn't afford it.Nichikuros - Peerless 831735 Nomex + Vifa NE25VTA
Digger8 - Small compact 8" sub with F3 = 20Hz
Madison-D and Madison-R - Tang Band W4-1720 + Vifa BC25SC06 or Beston RT003C (TM and MTM)
Jeffrey - Tang Band W5-704D + Beston RT003C
Jasmine - Fountek FW146 + Fountek NeoCD3.0 Ribbon in Pioneer BS21 Cabinet
