2.1 Minions III/Voxel System Build
Actually, I was exactly looking for something like that...a higher than Sonos quality table radio that looks nice.
I'm getting a bit too old to want massive booms and explosions
Originally posted by bsl100 View PostBTW.... Has anyone tried the Minions III and Voxel in one unit as a 2.1 boombox? The Voxel require a 7L ported enclosure and the Minions about 1L sealed each. So, for something about the size and shape of the Sprite, you could get a proper 2.1 boombox.
As blackie pointed out, that would have given a horrendous tuning situation. So far off the orig. design that I wouldn't even consider it a Voxel.
Re: 2.1 Minions III/Voxel System Build
Those are awesome looking!!! Ive done a couple versions of minions now and really enjoy them... I think I'm gonna do a cigar box version next and it looks like I need to do a voxel...
Again great looking build
Originally posted by camerakid View PostCan you tell me what port you used? Also, does it go below 40hz? My DB Plus 440's go down to 40hz, but I've always wanted to make a DIY speaker.
The port I used for the sub was 268-322.
Hope that helps...
Kevin
Originally posted by Jackson54 View PostI didn't know the sub plate amplifier had that function. Seems like it should work fine for my situation. Thanks for the info!
Kevin
Originally posted by Jackson54 View PostKevin007 I was wondering how you have the Dayton 25 watt amp and the lepai 2020 hooked up with each other and how they eq together?
I was at my wife's grandparents house last weekend and just to test I took the lepai 2020 and wolf's pc speakers to see if there older flatscreen tv had variable volume output control and it did through 3.5mm hookup for headphones. They were very impressed with the sound and I would like to build them a 2.1 setup and what you have here looks great.
Thanks!
Kevin
Thanks!
Originally posted by blackie View PostThanks for the response Kevin007. So you are using a 3" diameter port cut to 4 inches in depth? Glad that it's pumpin for you!!
Kevin
