Re: 10" woofer for 3 way
Gents, thanks for the replies, however I've decided to ditch the side firing approach and use a pair of small subs, front mounted instead. This gives me a bit more flexibility. Plus I feel the 10" was being wasted in a such a small volume.
Originally posted by winslow View PostCan the woofer even physically play that high due to the inductance?
Originally posted by Pete Basel View PostVoice coil inductance alone does not tell the whole story.
I doubt you could hear any difference simply due to VC inductance in a blind test.
Originally posted by Pete Schumacher ® View PostNot bad, but with a voice coil inductance over 2mH, I'd hesitate to use that woofer above 150Hz.
Since I'm in a similar boat, I've been shopping options as well. I'm pretty much narrowed down to the Acoustic Elegance TD10(s or h) drivers.
There are 4 different versions to choose from, depending on your needs. In your particular application, the H or the S version look the most fitting:
You can choose between a bit more efficiency or smaller box. I don't know if these fit your budget or needs entirely, but I'd give them a look. More than likely, this is the route I'll be going.
Originally posted by frangus View PostHi Pete, I read it here: http://www.avsforum.com/t/1134984/da...65-conclusions
Has anyone here had success with the rss265 in a 3 way?
I have no idea what the "teeter totter" is in reference to in that link. The RSS subs have a ringing cone like any metal cone, but it's well above 1KHz, even in the 12" woofer. Dan's posted response plot of the RSS265HF was exemplary with smooth, flat response to almost 1KHz before things started to get a little non-linear. Wolf used the RSS210HF in his "Attitudes" crossed at 800Hz and those speakers are still considered "top shelf." The only thing I can think of as to why the linked description has issues may have been due to some faulty conditions with the driver, like a loose dustcap or something else.
Originally posted by Pete Schumacher ® View PostI don't know what else you've read, but the RSS265 does fine to well beyond 400Hz. And I've used the RSS315HF as a woofer in a 3-way with a 2nd order 350Hz crossover with no problems at all.
This is the particular 10" model I have on hand. http://www.madisoundspeakerstore.com...aluminum-cone/
Originally posted by frangus View PostI'd need to model them, not sure how well they'd do in such a small enclosure
I just read elsewhere that the RSS265 does not play well higher than 100hz. Shame as it models quite well.
Originally posted by Face View Posthttp://www.parts-express.com/dayton-...-coil--295-510 I would model thses sealed with some boost at the bottom to see if they have enough headroom for you.
Originally posted by Pete Schumacher ® View PostWhat's your budget?
I have a pair of Scan Revelator Aluminum cone 10" woofers that have the ability to dig very deep in the right vented enclosure and have no problem crossing well above 250Hz if need be.
The RSS265HF also fits the requirements.
