Dayton Audio SA100 100W Subwoofer Plate Amplifier
Bravox PXW15D-2 15" DVC Subwoofer 2 Ohm Per Coil, wired 4 Ohm mono
Precision Port PSP-6OFN 6"
22" x 22" x 38.5" High external 3/4" MDF cabinet
Sub to be mounted in face, centered both ways. Amp mounted high rear.
6" x 1.7" port in 22"x22"base. ***Is using a port without a tube like this a problem?
Lined with a fiber insulation board (Celotex, Homasote etc.). Glued, screwed, sealed appropriately.
For finish: 1" x 1/4" strips of black walnut applied in a herringbone pattern. Sides and top in a rough slate tile, rear varnished or flat black on the MDF.
***Should I buy or make spikes for this, or can I just make wood-block feet and dowel them on like I would furniture? It should be well- weighted.
Looking forward to your input.
